Question about Whirlpool Washing Machines
How do i remove the cabinet to get to the pump ultimate 2 top loader
  • Whirlpool Master
  • 3,051 Answers
Hello there
Hopefully this will help i will post more information is a seperate post for you
Posted on Nov 13, 2010
Testimonial: "something so simple and yet so frustrating solved with just a little know how. Thanks"
  • Michael Thomas
    Michael Thomas Nov 13, 2010
    Have a bucket standing by to
    catch any left over water in the pump hoses, and remove them from the pump.
    The pump is held on to the motor by two spring clips. (Figure DD-4) Remove
    the spring clips and pull the pump off the motor shaft.
    When replacing the pump, make
    sure you check the pump discharge hose for any impeller pieces that may be
    clogging it. Also, when installing the hose clamps, put them in a position
    where they won't hit the cabinet when the machine wobbles off-balance. should look something like this
How do you open a top loader
You have to hinge console back by loosening screws in back corner of console. Then remove two gold clips that hold cabinet on. Pry with flat head screwdriver. remove wiring harness from lid switch and the whole cabinet will pull forward
Jun 13, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
How do i remove the lid and cabinet
The following link explains step-by-step how to remove the exterior cabinet on a Whirlpool top loader:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
The lid comes off with the washer case. If you have any difficulties, questions, or concerns, pease post back and let me know. I hope this helps you.
May 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a roper that spins but want drain
Your drain pump is clogged.
Remove the cabinet, remove the pump and remove whatever is clogging the pump.
The pump is located in front of the drive motor.
Mar 03, 2009 | Roper RAK2751WWH Top Load Washer
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How to replace the gear case for whirlpool washer lsn1000kq0
remove 2 screws on rear of console lift console forward and roll back remove the lid switch connector remove the 2 clips on each side pull rear of cabinet forwardand slide cabinet off remove screws in center of agitator under cap and pull off ..lean washer backward remove pump clips and hoses remove 2 screws in motor clamps remove clamps and motor remove 3 1/2 in bolts holding gearcase to bottom slide gearcase out remove clutch and reinstall on new gearcase if you go slow and take note reassembly not that hard
Nov 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leak
remove the 2 screws holding the console in, they may have trim on them.flip it up and you will see 2 metal brackets on left and right. pop thos off taking note how they are on there, disconnect connector on the top of the cabinet(door switch wires)lean cabinet foward pull towards you.it is know free of the rest of the machine. put back reverse of these directions making sure the back lines up properly with the cabinet.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer
hi thanks for the question. the cabinet has to come off.to do this. 2 screws 1 each corner of the console. remove. lift the console. 2 brass clips on top. remove. disconnect the wiring for lid switch. pull cabinet off. put washer on a block to raise it . its easier. . remove the clips that hold the pump on the motor. remove the motor. 2 screws 2 clips. replace coupling thanks the appliance doc
Oct 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
hi thanks for the question . i think the problem is with themotor coupling that is on the motor and transmission you have to remove the cabinet 2 screws on the console . remove .lift console . remove 2 brass clips on top disconnect lid switch pull cabinet towards you. remove the water pump 2 spring clips . remove the clips on the motor disconnect the power to the motor remove the motor . replace drive coupling thanks the appliance doc
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Oct 08, 2006 | Whirlpool Ultimate Care II GSW9650LW Top...
Washing Machines Logo
228 people viewed this question
Dan Webster
Dan Webster
Sal De
