Question about Ingersoll Rand Air Tools & Compressors
Ir2135ti runs when hooked up,in either direction
Sounds like the trigger is stuck internally
Posted on Nov 13, 2010
Were is the fuel pump relay on a 91 geo tracker also when I hooked power to the fuel pump it dindnt run
When you hooked power directly to the fuel pump, it may not have been grounded properly. If you're running power directly to it, and it is grounded properly, it should work fine, unless the fuel pump itself if bad. There is something called Ohm's law. it says you have to have power and a ground to transfer electricity. I am at a loss on where the fuel pump relay is. If the pump won't work with direct power, I can't imagine it being the relay.
Aug 10, 2013 | 1995 Geo Prizm
How do i hook my 5hp compressor up direct
By direct, you most likely mean continuous run where the compressor runs to set pressure then a spill valve or unloader will discharge the rest of the air. This can be done with a pilot valve available thru WWW.Grainger.com or ebay. Make sure that the thread sizes will work on your compressor. You do not have to remove the pressure switch, however the unloader must unload before the pressure switch setting. For an idea on plumbing, take a look at gas powered compressors or an electric RolAir compressor that has that feature installed. Good luck.
Oct 24, 2012 | Air Tools & Compressors
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
Cant figure out how it hooks up. Directions a really bad. It has a solid wire running to all fuses,a red wire running from fuse to switch and a black wire running out of switch. Where the hell do i hook...
You hook your HOT wire from your battery to the + terminal on the switch.
That HOT power goes through your fuse to a switch, when you turn the switch ON. the other wire from the switch gets HOT. This wire goes to your device.
So there is only one HOT wire connection. This is split by the panel to the six fuses and then the six switches. Wire from the switch to the device, such as anchor. The anchor motor must also be grounded to the negative of the battery either directly or through a grounding system like in a car.
Gary
Jul 26, 2011 | WHITECAP 6 TOGGLE SWITCH PANEL
How to network hp laserjet4 plus with dlink 628
Go to HP.com for the exact directions, for free. But in essence, you do NOT plug and play, but rather follow the install directions exactly.
Usually you are directed to eventually hook up the printer via USB, and the software makes the printer connect when you hook up the network cable.
ALL computers need to run the install after that "host like" process. Remember to remove usb connection when you are done.
Then install and navigate to the newtork location of the printer, on each machine in your network.
Oct 24, 2010 | Computers & Internet
Hook up vizio tv to fios box
Run HDMI from FIOS to TV directly, then run Digital coaxial or optical to the cbl/sat audio input of your receiver. That's it. If you have any more questions, just post a comment and I can help more.
Aug 08, 2009 | Pioneer VSX-D509S Receiver
Hd hook up for rca 52"dlp
If you have Direct TV HD the best way is to use a HDMI to DVI cable. If you only have the component (red/green/blue)connectors on the Direct TV Box that would be the best way. You will not have audio using the DVI cable, so you will have to run Red/White cable to the Audio Input.
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
There is no power to the fuel pump, the fuse is good, also if I hook it up direct it works
what are you by-passing in order to hook it up directly? If the fuse isn't bad but it runs if you put wires directly to the positive and negative wires at the pump, then I'd say it's a bad ground connection between the ecm/fuse box and the pump.
Jul 25, 2008 | Chevrolet Suburban 1500 Cars & Trucks
Air Tools & Compressors Logo
410 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
