Question about Briggs & Stratton Garden
DO NOT KNOW THE NAME FOR THE PART LIKE THE SIMILIAR TO AN IGNITION COIL BUT LOCATED UNDER THE FLYWHEEL
Its called the magneto
Posted on Nov 13, 2010
MY Stihl BR-550 Has a rebuilt Carb, Clean spark arrestor, New spark plug, fresh 50:1, valve adjustment, filter, new pull cord assembly. The issue...it binds then smooth when pulling, cant get any rpms
Suggest you try:
1) Flywheel key could be sheared. It is located under the starter drive cup/armature coil magnets just beneath the recoil assembly.
2) starter drive cup rubbing on ignition coil
3) ignition coil failed due to rubbing causing heat failure
4) valve adjustment .002" clearance
5) valve lifter cam worn or brokent
Jan 12, 2017 | Stihl Garden
What is the gap supposed to be between the flywheel and the ignition coil on a Husqvarna YTH20K46 Ride-On mower?
Put a business card between them and push coil up against card. Tighten screws or bolts. Remove business card. This is the best way without a gauge. PS Proper name is magneto not ignition coil. FYI :-)
Jun 03, 2016 | Husqvarna Garden
Briggs & stratton 206cc no spark
Hi Norman i know it sounds stupid but have you put the coil back on the right way? Also have you set the points and cleaned the little brass nipple under the fly wheel? If this is still failing it may be that the flywheel key is worn.
Jul 06, 2013 | Plumbing
Have no spark to spark plug 16ohv 201142b
It sounds like you probably have a bad ignition coil. It's located under the flywheel cover and is usually attached with two screws. The spark plug cable originates from it. You can gap the new one with a business card placed between it and the flywheel.
Jun 06, 2012 | Tecumseh Enduro Vertical Engine 16 HP 1in...
When i start it , it kicks and hurts my hand
The flywheel key is at least partially sheared. This affects the ignition timing, causing it to fire at the wrong time and the engine kicks back at you while trying to start it with the recoil starter.
The flywheel key is located under the flywheel. The flywheel is the round metal piece with all the fins on it. The flywheel is located under the recoil starter (part that has the pull string). Make sure that you use a soft metal key.
In the event that you do not know how this happened, it usually occurs from hitting something hard with the blades.
I hope this helps you out.
Jul 30, 2011 | Garden
I cannot find my ignition module
Your ignition control module is under the coil packs on the motor.
Jan 05, 2011 | 1991 Chevrolet Lumina
It's about Husqvarna 345 chainsaw. I would like to know the resistance value between spark plug wire and blue wire from ignition coil, and between spark plug wire and the ground and finally resistance...
The easiest way to test is on the machine. Remove the ignition switch wire from the module coil. Check the pole gaps of the module by inserting a thin business card into the gaps after turning the flywheel magnets under the module. Loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel slightly to release the card. Turn the flywheel one full turn to make sure the gaps don't close up further. Use a fresh spark plug gapped at 0.020" and try for spark. If nothing, replace the module. This gets around measuring resistances while trying to evaluate the module. Hope this helps!
Nov 21, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
16'' chain Saw wont fire
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Garden
How do I replace the condenser
The condensor will be located very close to the points, both are located under the flywheel. Points and condensor systems were used til the mid 80's, so if the saw is newer than that, it would have electronic ignition, and the condensor is normally part of the coil.
Nov 13, 2009 | McCulloch Garden
No spark
turn on your ignition and check your coil make sure you getting power to it by using light tester contact with the coil post + and -. things that wont make your electronic Ignition Control Module fire, Camshaft Reference Mark Sensor if is bad, this sensor located next to the flywheel and its sense the rotation of the flywheel sending the single to computer and comp. send single to the coil to fire as your distributor disperse the sparks to each plugs. assuming if the ignition control module are good. hope that help some
Jul 16, 2009 | 1992 Audi 100
Garden Logo
23 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
