Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
How to put on the flat belt on hoover mach 5 - Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
  • CarlT36 May 11, 2010
    totally useless answer
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=681386
Generic problem for all Vacuums
How to put on the
Posted by jamescook76 on Jun 18, 2008
How to put on the flat belt on Hoover mach 5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are 2 to 4 screws on the bottom of the vacuum and then the top cover will come off in order to change the belt or the bottom plate will come off and then you can get @ the flat belt. It’s one or the other. A suggested flat belt change is recommended every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 18, 2008
Hello,We have an Hoover Mach 5 Cyclonic vacuum that has no suction. We have cleaned and checked all hoses, belts & filters. Please help us.
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
Mar 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
I have a Hoover Mach 5. The beater bar will not rotate. I have taken the plate off of the bottom and sometimes it will rotate. I put the plate back on it stops. I have taken off any hair, string or...
replace the belts part # 38528-034 V belt and 38528-035 flat belt also inspect the belt groove on the brushroll if the new belt rides deep in the groove you will need a new brushroll. there is a tensioner for the V belt that tightens it when the handle is released
Jan 04, 2010 | Hoover Vacuums
On our Hoover U6445-900 (Mach 6.9) we replaced the small belt that goes to beater brushes in front of unit. Upon starting, the Hoover quickly got hot and smoky. We shut it off and looked things over...
are you sure you purchased the right size belt..the friction you speak of is usually caused by a belt not being the right tightness or a jammed beater brush
Dec 19, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Brush won't spin on my Hoover Mach 5
I love this vacuum but had the same problem.
SOLUTION:
take the roller off and flip the thin belt inside out. This fixed my vac and works great again.
Oct 12, 2008 | Hoover U5194-900 Mach5 Multi-Chamber...
The brush rollers on my hoover mach 5 won't turn. I've cleaned everything and checked the belts and everything checks out fine. I had the vacuum for about a year.
I had the same problem. The problem is the small v-belt for the roller brush (Hoover part# 38528034). Although it looks in good shape, it's been stretched too large for the idler to keep good tension. The tension on that belt varies with the handle geometry so if you slam handle all the way down the belt gets stretched a little bit each time.
Oct 06, 2008 | Hoover Vacuums
New main belt alignment for Hoover Windtunnel Mach 6.1. Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=853508
Posted by donlee300 on July 29, 2008
Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you may have a broken or cracked motor mount and the motor has shifted and that could be the reason that the belt is not running straight and aligned properly – if you have the vacuum less than one year – something like this would be covered under the Hoover factory warranty and to contact an authorized Hoover vacuum cleaner dealer in your area or to call the Hoover factory cust serv @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
167 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
