Question about Microsoft Computers & Internet
How can I install .net framework v1.1.4322.32bits.exe
  • Microsoft Master
  • 4,338 Answers
.net framework v1.1.4322:
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en
Bottom of this page:
http://www.computing.net/answers/windows-xp/install-of-net-framework-v114322/89017.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 13, 2010
How to install microsoft .net.frame.version5
you might need to download net framework error fix net framework
http://download.smartpcfixer.com/download/setup.exe
*SmartPCFixer will repair Windows Net Framework Error and registry data errors on your PC
hope this helps
Oct 09, 2012 | Computers & Internet
Tip
How To Completely Remove .Net Framework
Directions:
  1. Download the .NET Framework cleanup tool
  2. Open dotnetfx_cleanup_tool.zip and run cleanup_tool.exe.
  3. Download and reinstall the version of the .NET Framework you want, .NET Framework 3.5 includes .NET Framework 2.0 service pack 1 and .NET Framework 3.0 service pack 1.
Prerequisites:
Note: If you are installing on XP 64 bit or Windows 2003 you might need to install the Windows Imaging Component. The Windows Imaging Component 32 bit can be found here. The Windows Imaging Component 64 bit can be found here.
on Feb 20, 2011 | Computers & Internet
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
Problem signature Problem Event Name: APPCRASH Application Name: YahooMessenger.exe Application Version: 10.0.0.525 Application Timestamp: 4a8b5447 Fault Module Name: StackHash_b245 Fault Module...
download and install the following software updates:
1. Java Runtime Environment:
http://java.sun.com/getjava/
2. DirectX Runtime Web Installer:
http://go.microsoft.com/?linkid=9635483
3. Internet Explorer 8:
http://www.microsoft.com/windows/internet-explorer/
Next, you need to reinstall the Microsoft .NET Framework. Here's how:
1. Download and run the .NET Framework Cleanup Tool:
http://blogs.msdn.com/astebner/attachment/8904493.ashx
2. Download and install Microsoft .NET Framework 4:
http://go.microsoft.com/fwlink/?LinkId=147415
Reinstall Yahoo! Messenger using this link:
http://download.yahoo.com/dl/msgr10/us/ymsgr10us.exe
Sep 23, 2009 | Yahoo Messenger
Installation error
test my way, before installation, please install this program: "Microsoft .NET framework 3.0" and then try to install your program, but don't forget, after installing the .NET framework reboot your system
Nov 12, 2008 | Computers & Internet
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
NET Framework and msvcr80.dll programs
The msvcr80.dll is required for the software developed under microsoft C++. And if the microsoft visual C++ is not installed on that machine this raise error.
It sounds you are facing same problem, if then downlaod microsoft visual C++ redistributable package and install it on your machine. I think it will fix your problem.
Click here to download
Thanks
Iqbal
Mar 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
179 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
