Question about Microtek SCANMAKER 5900 Flatbed Scanner
Can you purchase the power supplier Model dsa-0151a-12 s. My scanner quit working and the power supplier was very hot. dve switching powersupply model:dsa-0151A-12 S Can this be my problem why it doesn't work I really like this scanner and hate to lose it
Dryer has no power, no lights, power from wall is hot up tp dryer, I checked with voltage meter and it's getting 120 volt on each leg
When there's no power at all (no lights) it's probably not the thermal fuse, but the powersupply fuse or the powersupply itself. If you're tech-savy you can try using a multimeter on the inside connectors of the powersupply to see whether there is any power going to the dryer's circuitry at all. If that's the case; it might be fried internal electronics ...
Jun 29, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
Where can i buy a switching adapter for our philips 10 in. digital frame? model DSA 12 PFA-05 FUS 050200 input 100-240 V output +5V
if you mean a switching adapter for your phillips 10 in. radio shack has an adapter set with multiple plugs and voltage and amps here is a link to one on amazon http://www.amazon.com/5V-1-2A-Universal-Power-Supply/dp/B001KU44HE that looking up your model should work. also walmart and best buy carry adapters with multiple plugs as well hope this helps let me know
Mar 14, 2011 | Philips Cameras
I have recently purchased the SVP Digital Film/Slide Scanner for the purpose of scanning slides and my initial response to the product is very favorable. I have however found that loading the slides into...
FixYa provides help and advice to people's problems and we are not affiliated with any companies.
You are best solution in this case is to contact the supplier of the fiim scanner or the SVP company.
Oct 02, 2010 | SVP PS9700 Film Scanner
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
99 town and country quit now even the warning lights dont come on
from ignition switch
key to run
black/orange power to fuse 11 and 12 in junction block and fuse 1 in power ditribution center
power to
black/white
dark blue
dark green/red
power all times
pink/black
red
pink
gray/black
check the maxi fuses
Mar 13, 2010 | 1999 Chrysler Town & Country
Scanjet 4300C
Hope this helps, but there's no specific model number, but here's a description:
Round barrel connecter with a positive center. Voltage regulator, power supply, powersupply, inverter, adaptor, adapter, transformer INPUT: AC 100V and OUTPUT: +12VDC/1.25A (12 Volt 1250mA)
And, a photo:
Aug 25, 2009 | Office Equipment & Supplies
Need to know power requirements for the kensington k33141 usb hub
hello,
i believe i know the answer. i have the kensington pocket hub se 2.0 model: k33141. it seemed to work with the adapter i found in our closet. it is a dve Model : dsa-0131f-05 us 13 and it outputs 5v 2.5a. the adapter has a thin profiile like it would be plugged into a strip. and it has an rf blocker which suggests computer equipment.
Apr 05, 2009 | Kensington (1500100) Networking Hub
Phillips 42PF5321D/37-Green power light, but no A/V.
bad powersupply, the powersupply has 4 voltages, +12, +5, -12 & +12 the led only tells you that the +12 is working.
Dec 16, 2008 | Televison & Video
Can anyone tell me if the 12 volt powersupply is 12 volt AC or DC ?
Model HER-48-12010
P/N: 68300021-0013
AC Input
DC Output
Sep 20, 2008 | Compaq S 200 Flatbed Scanner
Microtek SCANMAKER 5900 Flatbed Scanner Logo
125 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Michael
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
