Question about Sony Televison & Video
We have no picture or sound. The sttandby light blinks 7 times then a pause and blinks 7 more times. it keeps repeating this. This is a Sony Trintron TV
    Top Expert:
  • Sony Master
  • 74,630 Answers
Hello
Seven blinkings of stanbylight in Sony sets denotes a High-Voltage shutown problem. Not means the high line voltage, but the fault inside the tv itself. You haven't mentioned about the model number of your TV, yet I'm going to describe you considering this as a standard Sony problem.
The fault is mainly due to the internal power supply regulator section in your TV. It is now supplying voltage more than normal that it is meant for, as a result the EHT [Extra High Tension] voltage to the final anode of the picture tube goes higher than normal, and the microcomputer Ic inside your Tv detects this voltage difference and giving you the fault symptom in 7 continous blinks. That Ic is so programmed such, it will blink with certain times according to the fault comes inside, and helps us to locate the faulty section without opening the TV.
As I said above the fault in your TV lies on the power regulation section. You just open your TV and locate that section, which can be easly located as the main power just goes to that portion, and there will be a regulator normally Sony uses STR***** type IC regulators, which will be screwed onto a metal heatsink to radiate heat from it while it works. These will heat up to 80 degree C, while working, and the heat generated by this ic can cause loose solderings on its legs. You resolder its leg solderings, and suspected solderings around it, by applying a little more solder. In most cases this will resolve the problem. Ok.
Posted on Nov 13, 2010
No picture or sound. standby light on front panel
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony trintron--red lights
The 2 blinks is a diagnostic code that should indicate the problem circuit. This is unique to each model though. Can you confirm that the model in question here is KV-32FS120?
Thanks,
Dan
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron TV does not show picture. The standby light comes on and blinks 7 times then pauses and then blinks 7 times. This continues to repeat itself. TV never shows picture or sound. Light...
The usual cause of this is the sensing IC (there are 2 of them) on the power supply board. Sony usually recommends pulling the board and returning it to them for service.
Oct 20, 2008 | Televison & Video
Sony Trinitron 2002 Model # KV-32HS500 stand by light blinks 7 times, pauses and repeats. No picture or sound.
7 times blinks shows problem in Horizontal Deflection stage of tv and possible defective part can be Horizontal Output Transistor or Fly back Transformer.
If your are qualified tech person then go ahead to check above parts.
Sep 17, 2008 | Sony Televison & Video
Sony model # kv-36xbr800
The standby light should be blinking a repeating count with a 2 second pause between counts. Can you post hte count here please? That will help to determine the effected circuit and the solution.
Thanks,
Dan
Aug 01, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
