Question about Garden
Why does my chainsaw only run for a couple minutes at a time, cools off then cranks right back up to only run for a minute?
  • 1,041 Answers
I would check the air filter first. It may be clogged up with dirt, causing your machine to over-heat and shut down. If that is not the problem, then here is a Link to one of my Tips:
http://www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!!
Jim
Posted on Nov 13, 2010
  • Jim Parker
    Jim Parker Nov 13, 2010
    Sorry, but you will have to get rid of the ( http:// ) in order for the Link to work.
    Jim
Saw dies after working for fifteen minutes
Could be a multitude of issues, I however suspect the carb is in need of adjustment. The chainsaw while operating under manufacturer specs runs between 900 degrees (F) and 1100 degrees (F) if the chainsaw exceeds 1100 (which after 15 minutes of use this is possible) the chainsaw quits or what is called a lean seizure, the piston swells and scores the cylinder walls. when the piston swells too much it seizes the chainsaw, after it cools down it the piston will shrink and the chainsaw will run again. Too many times and the piston will score the cylinder causing damage and space between the cylinder wall and the piston.
Oct 10, 2016 | Garden
Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
May 31, 2015 | Cars & Trucks
My saw just cuts off after running it a couple minutes then it wont start back until it sits a little while
My first thought is the vent for the fuel tank is partially obstructed causing a slight vacuum to build in the tank when running, as it sets after it quits running the vent allows air into the tank slowly until the pressure equalizes.
Sep 19, 2014 | Garden
Uno fire 1100 manual
I am not sure if this was answered already. However, good to know the following. When i purchased my chainsaw I was told a few words of wisdon. At the end of the season and when your chainsaw is going on the shelf for several months, crank it up, run it a couple of minutes and then shut it off. Then drain all the gas out of it and then crank it up again and open up the throttle. It will run 5-15 seconds and then die out on you. That is good! What you did is remove all the gas/oil out of your chainsaw for storage. I was told, that if I do this, I would never have trouble starting it up. That was 13 years ago and I add new fuel at the start of the season and it cranks up, each and every time!. At this point, I would go with the easy solution to drain all your fuel and put an new spark plug in, add fuel and see if this helps
Aug 02, 2014 | Stihl Genuine 4180 007 1060 Set Of...
My chainsaw poulan p3314 will run fine for about five minutes, then cuts out and wont start until it cools down....???
Sounds like the engine is overheating and seizing. Most of the time this is a cooling or oil problem. Check the cooling fan for debris. Make sure you use the right oil mix.
Sep 16, 2013 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Have a model 359 runs for a couple of minutes then quick start it back up runs a couple minutes then stops.
Hi, The next time it shuts down on you, crack the gas cap and listen for a vacuum. If you hear that noise, clean the pinhole vent in the cap. This will allow air to be pulled into the tank as the fuel is being pulled out.
Best regards, --W/D--
Feb 04, 2011 | Husqvarna Garden
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Saw runs for 3-4 minutes then dies
check the spark plug
change the seals with new ones
check compression
regards Mihai71
Nov 26, 2008 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
