Question about Fuji Finepix S5800 Digital Camera
Fuji Finepix S5800
I need help with replacing an LCD on my S5800. I have a camera with a broken LCD and a replacement one on the way. What do I need to do swap them over? Any help would be much appreciated.
I have just done this very thing. I ordered a new replacement OEM LCD from a seller in the US listed on E-Bay. Even with postage it was a third of the cost of sending the camera to Fujifilm for repair (and Fujifilm wanted a couple of quid less than buying a whole new camera!). To Dismantle the FujiFim S5800 and get the back off the camera you need to remove 5 screws, and dont mix them up as they are different lengths. I used a set of those small jewellers screwdrivers to do this. Make sure you have taken the battery's out and taken the carrying strap off. First remove the screw on the side just above the flap where the memory storage card goes. On the opposite side of the camera where the carrying strap bracket is you will find two screws in the recess, just remove the one screw nearest the back of the camera. Now turn the camera up-side-down. You will find 4 screws around the threaded hole for a Tripod. Remove the two nearest the back of the camera (they are also the widest apart). Now open the battery hatch and remove the screw nearest the outer edge of the camera which is effectively below the memory storage hatch. The back of the camera should now be easy to lift away and reveal the LCD screen. Be careful as there is a small semi transparent printed circuit cable that connects the rotary switch to the main body of the camera. I chose to leave this in place as I was reluctant to remove more parts than necessary - however if you choose to leave it in place be sure support the the back bit of the camera as you do not want to strain rip or excessively twist this cable. The LCD screen rests in place between some guides and had a small piece of black tape holding the end down at the ribbon cable end. Use the blade of one of the screw drivers to lift the corner of the tape away. and you can lift the LCD screen up. The Ribbon Cable looks like a push fit but in fact there is a tiny black hinged section holding it in place. Be very careful and lift this up and the old cable can be released and removed. You will find the same system holding the cable in place for the rotary switch so if you want to give yourself working room you could disconnect that in this manner. Fitting is now a reversal of the removal process. Put the ribbon cable into the socket as far as it will go, No force will be required. Clip the tiny black hinged section down and this will lock the cable in place. Re-assemble the camera and remember to fit the memory storage hatch while doing so. Note: the storage hatch has a small plastic lug that presses a switch. When the hatch is opened it cuts the camera off (personaly I think this is a bit of weak point in this camera's design, if this lug or switch wears or breaks the camera is not going to work - but that is by the by for now). Presumably this is so you don't add or remove memory cards while the camera is powered up. This means it is difficult to test the new screen without putting the camera back together. But all being well you should be back up and running. Just take your time, study all the parts first and you should be ok. Don't come crying to me though if you break it - remember all repairs are carried out at your own risk.
Posted on Jul 03, 2009
    Problem Solver:
  • 7 Answers
There should be a section in your manuals. it is not that hard from looking at mine. Should just be unscrewing and removing and replacing said part.
Let me know how you get on.
Good luck.
Posted on May 13, 2009
Fuji FinePix S5800. Where can I get a replacement battery door?
Fuji service centre may sell you one through a dealer
Aug 23, 2015 | Cameras
How to fix lcd screen on fuji finepix s
You will probably need to send it off to a repair facility to get it fixed. One of the lights may be out, if you cracked it it will have to be replaced.
Feb 25, 2013 | Zeikos Fujifilm Finepix S5800 Digital...
Flash fault S5800
If blub not flashing then its a flash tube cut off & need replacement.
Aug 09, 2012 | Fuji Finepix S5800 Digital Camera
My screen is not working on my cam can this be fixed? can still take pics just not vies them
Hello
Yes, this can fortunately be fixed for about $50 including labour. I would suggest that you first take you camera to your nearest repair store, let them have a look at the LCD settings before you replace a screen which is not broken.
Please feel free to contact me if you need any further assistance.
Kind regards
Andrea
Nov 11, 2010 | Fuji Finepix S5800 Digital Camera
Fuji finepix 5800 helpppppppp
You dont need the fuji software to view or print. You can use a card reader to retrieve your pics to hard drive and use MS Picture viewer to print from OR get Adobe photoshop.
you can also contact Fujifilmusa com/support for replacement software.
Please rate our help to keep the free service online
Aug 30, 2009 | Fuji Finepix S5800 Digital Camera
Where can I get a LCD screen or how much is it to
I can buy a new screen for the S5800 from my suppliers and fit it for you for approx £45.00 including postage back to within mainland UK only. You would need to send the camera to me.
Contact me marielowther@live.co.uk
Aug 24, 2009 | Fuji Finepix S5800 Digital Camera
I need a new lcd screen for my fuji finepix s700, where can I find one??? My lcd screen on my Fuji film S5800 has stopped working. it is white with stream line colours through it. Can someone please help.
Sounds like your LCD screen is broken. Did you drop the camera? You may be able to find a screen or a broken same model camera with a good screen on eBay. Changing it out, however is NOT for the faint of heart. You will need tiny tools to work on tiny parts with very small electrical connections, a steady hand and nerves of steel with a service manual at your fingertips so that you disassemble only what is needed in the correct order and don't do additional damage. Still want to try it? I recommend taking it to a reputable camera store and getting a quote to repair it. Weigh that cost against the cost of replacing the camera. In the meantime, switch over to the Electronic View Finder. Good luck. (FYI: I will undertake the repair of anything short of a nuclear device, but I will not try a digital camera of any kind.)
May 14, 2009 | Fuji Finepix S5800 Digital Camera
Fuji S5800 spare parts
I would see if Fuji would let you send it in direct to them. Alternatively search on ebay for spares or repair camera that you could take the pieces off of.
Good Luck.
Jan 19, 2009 | Fuji Finepix S5800 Digital Camera
Brand new camera - no image in view finder
Have you tried to format the camera? Alternatively, and don't mean to sound rude but have you taken the lense cap off?
Are you getting any menu options on the lcd screen or is it totally blank? If this is the case then likely there is a problem with your camera and you should speak to who ever you bought it from.
Good Luck.
Dec 03, 2008 | Fuji Finepix S5800 Digital Camera
Accessories for Fuji Fine pix S5800
You Can not put additional flash on S5600, S5700 and S5800.
Jun 18, 2008 | Fuji Finepix S5800 Digital Camera
Fuji Finepix S5800 Digital Camera Logo
555 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
