Question about Kenmore Sewing Machines
I think I have a tension problem??? I'm sewing a straight stitch but the underneath stitch is loose.
    Problem Solver:
  • 16 Answers
Try re-threading the top thread with the presser foot raised so the thread is properly set in the tensioner, and the tension should be set in the 4 to 5 range normally. Then make sure the presser foot is lowered to apply the tension to the upper thread to sew
~<Ray>~.
Posted on Nov 13, 2010
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
My stiches are loose on the bottom of my banner - is it the bobbin or a tension issue?
If the threads on the back are loopy, you need to tighten the top tension. If you have a spare piece you may want to run some of the plastic through the machine until you get the tension correct. If the top tension is too loose, the stitching will just pull out.
Jul 16, 2014 | Juki DDL-8700 Industrial Straight Stitch...
The underneath stitches are loose
When you see loose stitches underneath your sewing, it usually means that the top tension needs tightening. Write down where your tension disk is before you turn to a higher value, then sew. Keep doing the above until you reach the correct top tension. The reverse of this would be loose stitches on top which means the bobbin needs to have the tension screw increased, little at a time, about 1/8 ". Sew and repeat until the stitches are equal.
Sep 05, 2010 | Sewing Machines
Sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
I always have problems with loading the bobbin, when I think it is loaded properly and begin sewing, it balls up and doesn't stitch properly on the back side of the fabric. Top stitch is fine, underneath...
the bobbin case has a small screw on the side for adjusting the tension, use a tiny screw driver to finely adjust the tension and sew on a scrap until the stitch looks good always turn the screw clockwise to turn the tension up and counter clockwise to loosen it
Dec 13, 2009 | Bernina Sewing Machines
No bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
When making a straight stitch or Zigzag stitch, makes loops underneath the fabric This is for a Singer sewing machine model 5817c
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Feb 21, 2009 | Singer 5050 Mechanical Sewing Machine
Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Mar 25, 2008 | Bernina Activa 130
Sewing Machines Logo
56 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
