Question about Nintendo Wii Console
Setting up Wii with TV
We cannot tune into an AV channel (or any other channel) on the TV which give us a clear/dedicated picture for set-up of the Wii. The Wii set-up screen appears (in a ghosting manner) on channel AV-5 which is the DVD channel on our TV. Out TV is a Thmpson, approx 8-9 yeears old, we only appear to have AV & AV5 and nothing in-between. Could this be a TV problem? We would be grateful for your assistance. Phil & Maria
  • karibarth Jun 20, 2008
    the manual that i have is telling me how to connect a yellow and red and white cable but the one that i have is blue/green/red...i connect it to the tv and i get a fuzzy picture that is not readable. what should i do?
  • Anonymous Dec 25, 2008
    we have an older tv but we can get the wii and all the plugs where they go, the only thing we can not do is find the av channel where the menu will show up
I'm 60 plus years old. Do I connect the AV cables to my TV or to my SAT receiver.
Posted on Jun 20, 2008
Have new 55ux600u toshiba. Hooked up a one year old wii and get no color
The 55ux600u toshiba hdtv has a setting that needs to be changed with the wii in order to get color.
1. Click 'Menu' on the TV remote 2. Arrow over to 'Preferences' 3. Arrow down to 'AV Connection' 4. Click 'OK' 5. Arrow down to 'AV Input' 6. Change setting from 'ColorStream HD' to 'Video' by clicking the right arrow. 7. Hit the'Exit' button on the TV remote.
This will give you color for your Wii. You will have to change this setting back in order to view DVDs in color. :-)
Jan 01, 2011 | Video Game Consoles & Games
Can not find my instructions book to turn my freeview tv into my video recorder
If the TV has a scart then you don't need to tune it. All you need do is connect a scart to the VCR and TV. Then when you want to record anything, set the VCR to an AV setting instead of channel 1 etc. You need to set it to the one with the scart, as the VCR will have more than one AV looking at it's picture. You then just press record. You won't be able to change channel, or the VCR will record that channel instead.
If this is a problem, get a freeview box and just have it connected direct to the VCR.
If the TV has only one scart, you can get one of these boxes below.
Feb 09, 2010 | Sharp VC-H812U VCR
Old Sony Triniton KV-M2 with no instructions how to tune in Wii?
Jan 02, 2009 | Televison & Video
Wii tune in on sony kv 28 fx
sir u can connect both as front n back,connect only on av input n select the av button in your remote once u press u can view the first input then as followa second
Dec 26, 2008 | Sony KV-28FX60 28" TV
Has sound but no video picture for game playing
try changing the av to another channel or if you have access to a front panel or side panel on the tv set, try using this for your av leads 'red' 'yellow' and 'white'. Also check that the av lead is correctly inserted into the back of the wii
Oct 25, 2008 | Nintendo Wii Console
You tv needs to have av plugs. Yellow for video in Red and White for Audio in. These need to be in the "in" ports. then you can turn to the right av channed it should be before channel 2 so just keep going down. If your tv has more than one set of av in ports there will be more than one av channel below channel two.
Aug 01, 2008 | Sanyo DS31520 31" TV
Program channels
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Finding the correct channel on the TV for Wii
ok. push tv video button on your tv,
first turn on your wii, be sure that the av cable are connected to ur televison properly. Then turn on your tv start from channel 1 then scroll down the channel button until you locate the blue screen or logo of wii.
Jan 24, 2008 | Video Game Consoles & Games
Snowy picture and Yellowy Whites
Make sure the TV setting is set to or . A power surge may have reset your ?cable-ready? TV. Check the cable setting on your TV and make sure it is set to or . If a VCR is connected: * The VCR needs to be on channel 4. * VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. If a converter is connected: * Make sure the TV is on channel 4. * TV may not be ?fine-tuned? to channel Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * Determine if the converter is bad. Locate the cable wire coming in to the room and connect it directly to the back of the TV. If the picture is clear, your converter needs to be exchanged. Give us a call or stop by your local office and we?ll switch out your equipment. Check the fine-tuning of your TV
Jan 11, 2006 | Fujitsu Plasmavision P42VCA30EH 42 in....
Nintendo Wii Console Logo
251 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
