My Pioneer SD-P50A3 tries to turn on but after a brief second turns back off again. Any solutions and advice would be greatly appreciated. Its been a great TV otherwise.
  • bceeingu Nov 13, 2010
    Thanks for your response and direction.
  • 12,061 Answers
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Service manual at the below link.
The service manual, http://www.mediafire.com/...0Projection%20TV.pdf,
another link below..
http://www.manualzone.com/ShowProductsForModel.do?model=LNG1.Dyn.M99913962KYWRDS_Pioneer_SD-P50A3-K_SDP50A3K_service_manual_repair_manual_schematic_diagram_owners_manual_users_manual_parts_list.html
Posted on Nov 13, 2010
Pioneer 50" SD-P50A3-K
Your TV is elderly and deserves retirement.
Oct 29, 2017 | Televison & Video
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
The fuse (FU 105) of my Pioneer SD-P50A3-K burned and I swapped it. Now when I turn on my TV it stays on for a few minutes and turns itself off; I turn it on again and the same thing happens. I believe...
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time. Based on the above method you must be able to locate the area of fault and solder the sections.
Oct 06, 2011 | Pioneer SD-P50A3-K TV
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at djstvrepair@comcast.net
Sep 15, 2009 | Pioneer SD-P50A3-K TV
Tv turns off
cant solve, but my problem is identical!
Oct 05, 2008 | Pioneer SD-P50A3-K TV
Pioneer projection tv SD-p5oa3
only codes for pioneer tv are 0166 0679 otherwise
Mar 11, 2008 | Pioneer SD-P50A3-K TV
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
Tv keep turning off
It's the power source.
Sep 30, 2007 | Pioneer SD-P50A3-K TV
Help
Hi tedski have a tech look at your tv the problem is in the power supply or related circuit.good luck
Apr 26, 2007 | Pioneer SD-P50A3-K TV
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
Electro Med Services...
