Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
The chuck is misaligned, how to I get them even again?
  • Dewalt Master
  • 7,733 Answers
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
The chuck on my Craftsman C3 drill won't stay tight
If you have a keyed chuck then yes as the jaws are not parallel any more from wear. If keyless then the thread inside the chuck cover is damaged and not tightening properly. So again yes a new chuck will be the answer.
Jul 29, 2013 | Craftsman Drills
Removing chuck
You don't say which drill you have, but this is one method.
Remove the left handed screw from inside the chuck, put the drill into low gear then lay the machine on it's left side, fit a suitable spanner on to the slot behind the chuck and arrange it so that the spanner is against the work surface. Put the chuck key into the chuck and give it a hard blow so you knock it in an anti clockwise direction. If it is a keyless chuck or you don't have a key try holding the short end of a large allen key in the chuck and knock the long end in a anticlockwise direction. This will work even if you don't have a spanner to fit behind the chuck but you might have to hit it harder. If you have a vise after removing the screw hold the chuck in a vice and fit the spanner behind the chuck and turn it anti clockwise.
Jan 03, 2013 | Makita Drills
How to remove chuck from hitachi d10vf
Remove the left handed screw from inside the chuck then lay the machine on it's left side, fit a suitable spanner onto the slot behind the chuck and arrange it so that the spanner is against the work surface. Put the chuck key into the chuck and give it a hard blow so you knock it in an anti clockwise direction. If it is a keyless chuck or you don't have a key try holding the short end of a large allen key in the chuck and knock the long end in a anticlockwise direction. This will work even if you don't have a spanner to fit behind the chuck but you might have to hit it harder. If you have a vise after removing the screw hold the chuck in a vice and fit the spanner behind the chuck and turn it anti clockwise.
Nov 14, 2012 | Hitachi D10VF 3/8" Chuck Electric Drills
Bosch 12V cordless drill PSR 1 ?ES-2 One of the three jaws unscrewed a little and protruded beyond the other jaws by approximately 4 mm but has now completly unscrewed and fallen out. I can not unscrew...
It is left hand thread and yes sometimes you have to use a little force to loosen it. I don't know if you will be able to reinstall the jaw from the chuck, I havea detailed instructions on chuck removal in my tip section.
Aug 30, 2011 | Bosch Tools & Hardware - Others
How do you work the keyless chuck on the 6.5 amp 3/8" rear handle pro drill?
Most drills with the keyless chuck work this way. Put the drill into reverse. Grasp the chuck with your left hand, and then pull the switch slowly. This should release the chuck. If your drill has no reverse, then grasp the chuck again with your left hand and hold the drill with your right hand. Turn the chuck with your left hand quickly, this should release the drill as well.
Mar 17, 2011 | Craftsman Garden
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
My 18v ryobi cordless drill does not hold a drill bit even tho i hold and tighten the chuck with my hand. It will hold for a wile but will eventually fall out. Thanks
Abrupt stops can loosen the ratcheting chucks. Before the invention of those chucks we had the ones that required a key. The proper way to tighten them is to alternate between all three position in order to "seat" the jaws on the bit evenly.That all but guaranteed it would not come loose I assume you have a ratcheting "one handed chuck". ther's only one way to tighten them and you don't get the same grabbing force. The only thing I can suggest is to try to eliminate abrupt stops or try cranking it tighter.
Jun 14, 2010 | Ryobi 18v Variable Speed Right Angle Drill...
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is...
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
May 29, 2010 | Craftsman Single Speed Rotary Tool
My chuck releases when i use it in reverse.
does the chuck unscrew?? If so what you need to do is tighten the chuck again and look for the chuck retaining screw that locks it into place, you should be able to buy one at any local tool repair center. they are left hand thread. if the jaws are releasing then the chuck might have to be replaced. Let me know if I misunderstood the problem and I will try again.
Jan 02, 2010 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck removal
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Sep 22, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
231 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
