Question about Samsung LN-T4671F 46 in. LCD Television
Using Remote- TV keeps clicking for about 10 minutes before the picture/volume stay on
  • Samsung Master
  • 12,061 Answers
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should really be removed from the Power and not used),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Posted on Nov 13, 2010
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
How do I override the password on a Toshiba cx32f60 tv? All channels above 13 are blocked. I want to unblock all of them. The remote is a Toshiba ct-9809.
Hello
Disconnect the AC power for at least one minute to reset the clock running inside the circuit.
Adjust Volume to Minimum using the Volume Down button on the front panel of the TV.
Press and Hold the Volume Down button on the front panel of the TV and the "Zero" button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password. OK.
Nov 04, 2011 | Toshiba CX32F60 32" TV
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
The volume and picture on my LG 42LB1DR TV shuts off by itself
check the menu for power saving option if it`s on shut it off.
Aug 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Samsung LN-T4671F 46 in. LCD Television Logo
Jerry Greenberg
Jerry Greenberg
