Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Refrigerator part is room temperature but the freezer is hard frozen. There is power and the lights are on. Why isn't the top compartment cold?
  • KitchenAid Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Nov 13, 2010
Refrigerator not cold enough and freezer is too cold making food very hard? water seems to leaking on bottom of freezer and refrigerator.
Refrigerators with attached freezers typically keep the two compartments at predetermined temperatures, but failure of some components can lead the refrigerator to seem warm while the freezer portion completely freezes.
Fan Issues
According to the appliance website Appliance Aid, many freezers contain a fan that blows cold air throughout the freezer and into the attached refrigerator. If this fan fails, the site explains that the freezer may become too cold; the refrigerator will not receive air circulation from the freezer, though, and will remain warmer than normal.
Air Damper
Appliance Aid also notes that most refrigerator and freezer combinations contain a damper that regulates the flow of air between the two compartments. If the damper sticks or fails to function properly, it may restrict the flow of air from the freezer to the refrigerator. The result of a failed damper would be a completely frozen freezer and a warmer than normal refrigerator.
Hope this would help.
Good day!
Sep 06, 2011 | Kenmore Refrigerators
Westinghouse RJ532, 530 Litre, Frost Free Fridge/Freezer keeps stopping - if we move the little red dial in the fridge under the air temperature control it starts up again, goes for awhile and then stops....
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
Mar 16, 2008 | Refrigerators
I have a Magic Chef MCBR1000W. The recent east coast earthquake shook the freezer door open while I was away on vacation. When I returned three days later, the freezer compartment (open) and refrigerator...
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
Aug 28, 2011 | Magic Chef CTN1521 Top Freezer...
It is warm in the refrigerator and we have the control set on maximum cold
the damper vent door in between the freezer and refrige compartments isnt opening or the evaporator fan isn't operating as long as the freezer is ok,then this door is at the rear floor of the freezer and the roof of the refrige compartments and is behind a plastic grille remove this grille to see if door is frozen open or broken
Jun 01, 2011 | Kenmore Top Freezer Refrigerator
The top compartment in the refrigerator is cooling effectively. But the lower compartment in the same refrigerator is not at all getting cool. Why is this so?
your damper vent door from the freezer to the refrigerator compartments is either stuck or frozen shut from moisture,sometimes they break and jam too,if this door doesnt open and close your food will get too warm or cold the door needs to move to keep the temperature correct
May 13, 2011 | Whirlpool ET1MHKXM Top Freezer...
The freezer stops working when the room temp drops below 60
Refrigerator operation is controlled by the internal temperature . When there is very little ambient heat available to leak in to cause it to cycle more frequently and there is no door traffic to be a heat source the freezer temperature will increase. Keep the room heated to a higher temperature or remove frozen products is the answer. A small chest type freezer will keep food frozen while you are away and have the heat turned down.
Nov 11, 2008 | Refrigerators
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
152 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
