Question about MidiLand MLi 450 Computer Speakers
I need wires and an A/C adapter for my speakers since I can't find them anywhere. Do you sell these items or know where I would be able to find them? Thanks.
How can i add my add on amplifiler adapter to my back speakers?
most places that sell car stereos sell a tap adaptor kit costs about 20 bucks or more it hooks right to factory radio plug in dash and lets you hook any aftermarket radio/amp right in as all the wires are marked for there function (just match em up) No cutting and splicing required
proper kit is specific to your make and model car/truck
May 09, 2014 | 2003 Mercury Sable
Hello I just bought a new stereo for my mitsubishi galant 2002 but i need to know the wiring diagram in order to make the installation if anyone can help thanks
Wiring adapters are available for nearly every make of vehicle, which allows you to plug right in to the original radio connectors. They come with wiring diagrams, and are nearly idiot proof. They cost usually about 10 to 15 dollars, and are available just about anywhere that sells car stereos. This also allows you to reinstall the factory radio when it comes time to sell the car and you want to keep your stereo.
Sep 05, 2011 | 2002 Mitsubishi Galant
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
Harman kardon hk195 speaker set - where can i get a new power adapter?
If you still need the power adapter for the HarmanKardon HK195 speakers, I have an extra one which I will sell reasonably. I know it's been 6 months since your post, so it may be outdated. If you are interested,, please post and I will let you know how to contact me.
May 12, 2010 | Harman Kardon HK206 Computer Speakers
I want to sell my Pioneer 10'' 350W BAND PASS BOX Car Speaker
Search google the model of the pioneer, and try and find a used or new price and go from there.
Boxes are cheap and can be picked up locally anywhere for around $20-30 bucks used so dont charge a rediculous amount because it has a nice box.
For instance if your sub was $100 new. and then you bought a box for $30-50 new.
i would probably only sell it for $80 Max that is in PERFECT condition not blown or anything.
nobody will buy something that is $20 cheaper than retail priced especially if it is used.
I have been in sales and online sales for years.
Selling used items your prices stay low so the sale can happen. Priced to high people will just go buy it brand new if they want it.
I would recomend selling through Craigslist.Org. Local and easier than Ebay
Feb 10, 2009 | Pioneer Car Audio & Video
FINDING THE CORD TO THE SYSTEM FROM THE SPEAKER
From looking at the manual for your surround sound system
http://resources.jvc.com/Resources/00/00/93/GVT0150-001D.pdf
It looks like it just uses the regular spring-loaded clips to hold the speaker wire in place. All you need is regular copper braided speaker wire, nothing fancy. Then you strip about half an inch of insulation off the end of the wires, and pull back the spring loaded clip and put the wires in, then release the clip so it clamps down on the bare metal.
Speaker wire you can get from anywhere that sells the actual systems. I know places like Radio Shack (The Source by Circuit City) sells spools of it. Any other electronics store probably sells it too. It's common stuff.
Dec 13, 2008 | JVC TH-C6 System
Dual xdvd700
dual sells them from their website for about $30
Jul 24, 2008 | Dual XDVD270 Car DVD Player
Speaker will not turn on
See if has a fuse anywhere. These are throw away items. It might be time.
mike
May 09, 2008 | Brookstone Outdoor Wireless Speaker...
MidiLand MLi 450 Computer Speakers Logo
18 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
