Question about Maytag MER6769 Gemini Electric Kitchen Range
Maytag Gemini electric double oven: Oven Control pad is not responding to touch - cannot use any oven; display looks fine - no error messages; cooktop is working fine. Any suggestions or repair manual source for this control pad? Thanks.
I have the same problem with my stove but I do have auto select for the lower stove as well as keep warm for the upper,is there a reset button?
Posted on Nov 21, 2010
I unplugged my maytag gemini electric double oven and when I replugged it only the cancel and keep warm buttons for the upper level worked, the lower oven buttons worked, but no lights, also only the 1, 2, and 3 control buttons worked...no time or clock buttons would work, but the time was displayed. After removing the back of the oven to check the control panel, my husband was checking the connections to the control panel when he said one of the wide wires (there are 2 to the right of the control panel) had come off, after reconnecting it we plugged it in and everything was working again. Seems it was just a lose wire. So, before you dish out the money for a control panel, please check all the connections to make sure nothing is loose.
Posted on Jan 23, 2013
Repair man fixed top oven probe sensor due to a F1-1 error code. Top oven is still giving the same error code. Repairman wants to come back and charge 200.00 bucks again to replace bottom oven sensor.
The electronic control could have a bad touch pad that is causing this. You may need to replace the electronic control itelf. It is expensive almost 400.00 dollars.
Nov 20, 2014 | Maytag Gemini 30" Self-Cleaning...
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
Have a F1-2 error for my maytag range.. the stovetop works fine but the ovens don't
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness.
Jan 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
. THE MESSAGE APPEARED WHILE I WAS CLEANING THE
F1:-4 Runaway Clean Lower oven Check oven temperature sensor, replace if necessary
Nov 09, 2009 | Maytag Gemini 30" Self-Cleaning...
F1 error code for Maytag CWE5800ACB
Defective touch pad or membrane, usually the touch pad.
Dec 24, 2007 | Maytag CWE5800A Electric Double Oven
Maytag MER6769 Gemini Electric Kitchen Range Logo
742 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
