Hello there, I have the samsung power board BN44-00134A and although most people that have problems with it are saying that 3 or 4 capacitors are blown and bulging or leaking, but no matter what the audio works pefect and the screen will sometimes work for a few min after turning it on then will just cut off. Hope someone can help....
  • 11,361 Answers
You may dead or dying 24vdc for the backlight inverter board or bad inverter board, or the main board is not sending the signal to turn on the 24vdc or the backlight inverter.
http://www.shopjimmy.com/samsung-bn44-00134a-power-supply.htm
The top of the caps should be perfectly flat, bad caps can also look normal but can have high ESR.
You need to do more troubleshooting.
First, look at the screen in darkened room when the TV goes out to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 13, 2010
In my LCD TV i am getting half the picture is normal and half in white color
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Samsung and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 24, 2011 | Samsung Televison & Video
Please why is my Samsung LCD red power light on, but the tv can't come on?
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
Hope this helps
Dec 09, 2010 | Sansui LCDW2300 23 in. Television
Hello i have a rca hd52w59 and i unplugged it for about a week now i cant get it to come on. i hear it come on but it shuts itsself off
You are not the only one I can tell you that. I had the same problem with my Phillips 42 in. LCD HD TV.
Solutions?
Hope this helps
Dec 09, 2010 | RCA HD52W59 HDTV Projection Television
Tv turns itself offon an irregular basis
Solutions?
Hope this helps
Dec 04, 2010 | Samsung DLP HL-P5663W 56" TV
My samsung 46" hdtv does
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
Dec 04, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
When i try to turn the tv on the little red light on front of the tv turns on and the tv makes a sound but before even showing any image the tv turns off itself and it keeps turning on and off on its own.
Solutions?
Hope this helps
Nov 13, 2010 | Samsung LA40A450 40 in. LCD TV
Samsung TV turns itself off every 10/15 minutes
Solutions?
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
TV set turns itself off after I press power button
Solutions?
Hope this helps
Jul 01, 2010 | Samsung PCL5415R TV
The tv picture vanishes and there is multi-colored lines on the screen for a second then shuts off and then will turn itself right back on and it will keep doing this
Solutions?
Hope this helps
Mar 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Tv just turns itself off and then starts clicking like its trying to turn on and off
Solutions?
Hope this helps
Mar 03, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
Televison & Video Logo
593 people viewed this question
Top Televison & Video Experts
