Question about LG Washing Machines
I have just purchased a LG WD14030D front loader washing machine can anyone please tell me what all the symbles mean and how long each wash program takes. I just put a load on cotton quick and it will take 2 hours. Help please
taran_2005
  • 10515 Answers
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Posted on Jun 17, 2009
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
SOURCE: beko AA class washing machine 1000rpm WMA 510W
If you search on the Beko website, you can download manuals for their machines (including the 510W).
Posted on Apr 24, 2008
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
LG washing machine LE code comes up . WD14030D . What can I do to fix it? Claudia
LE code is an overload in motor. You might be washing too many items at one time. Towels are heavy when wet.
Dec 29, 2015 | LG Washing Machines
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
Front loader won't spin, just after 2 mins up into the cycle it comes up with message le. Can you help please?
Hi just read your posting.Now I need to know the make and model of your machine.It sounds like you have an LG front loader.LE on the LG front loaders means your HALL SENSOR which is attached to your motor is faulty.Please reply with model number and I am sure I can help you.Looking forward to your reply.
Sep 11, 2010 | Washing Machines
When washing clothes my machine says oe and still has water in it
the OE flashing code means there is a drainage problem.
check hoses for Crimping or Clogging.
Hope that helped
Please Rate Me
George
Apr 29, 2009 | LG WM-2277HW Front Load Washer
My LG Tromm washing machine WM1812CW keeps coming up with error 0E. how can I fix it.
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Jun 01, 2008 | Washing Machines
Door not opening LG front loader washing machine
Try: Program the select knob at 6 o'clock position. Speed at 9 o'clock. Press pre-wash and the power button together for 4 to 5 seconds. Hopefully it will unlock.
Sep 24, 2007 | Washing Machines
Washing Machines Logo
217 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
