Monitor or Desktop itself problem?
Everytime I start-up my computer I see these white lines (circle around with red see image below) and my computer takes about 10 minutes to start-up? Is it a monitor or my computer itself problem?
    Master:
  • 377 Answers
That status line was designed together with your OS, it seems that your PC was getting slow in boot..
A number of factors, having little to do with the age or capabilities or your system, can create excruciating system slowness. They include the following:
Operating System
File System (how you've organized files on your PC)
Applications
Hardware
The Windows OS (operating system) is notoriously inefficient, which can affect performance. The file system also impacts Windows and hardware performance. How you work with applications can improve system speed, as can some basic hardware updates.
Posted on Jun 18, 2008
Play back screen does not show any image it is just showing a blank white back ground
A component called CCD IMAGER is faulty and needs replacement, Basically the component works as an eye to view the image when it start malfunctioning screen and viewfinder does not show image. The detail of said part is given below:
Part No. Description
8-753-244-71 ICX611NKF-13 (CCD IMAGER)(HC51E/HC52E/HC53E/HC54E)
For convenience area is marked with red circle in the picture below:
Thanks
May 19, 2011 | Sony DCR-HC52E Mini DV Camcorder
Monitor image is "posterized"...red,yello, blk and white only
you have defective RGB circuit, or re solder all CRT Board maybe you have lost contact at the RGB CRT Board. RGB means red, green, blue. CRT means Cathode Ray Tube.
Oct 08, 2007 | Apple Studio Display 17" CRT Monitor
Odd red fuzzy screen on desktop
Hardware failure in either the video chip or the lcd panel itself. To check which connect the laptop to an external monitor and see what appears: if the lines are still there then it's the chip - unreplaceable, the entire laptop is good for the skip; if the image is crystal clear then the panel must be replaced. If the laptop is still in warranty send it to them.
Jan 09, 2010 | HP Compaq nx7400 Notebook
Stripes appear on monitor at bootup
I decided to change the background of my desktop and it works.
May 14, 2009 | Gateway FPD1760 17" LCD Monitor
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Monitor Lines
Okay it is definetely the Computer. If lines like that occur it looks like a corrupt system file. I wish i could help you further but i specialize more on FPD problems.
If you have software that changes your boot up picture, it might have made the image you are describing. Thats the only thing i can think of.
Theres software such as WindowsBlinds(just and example) that do these kind of effects.
I hope this helps you get closer to your solution.
Jun 20, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Is it a monitor, desktop or other problem?
it will appear because you did not shut down your computer properly,try to consult to computer technician so they can fixed your computer,its not the monitor its the cpu.
Jun 18, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor Screen problem
no this is not the problem of your monitor. sometimes it cames while loading operating system. it useually cames when you hybernet your computer.if you dont shutdown and make hybernate then this will appears in next time while you on your system.
Jun 18, 2008 | Computers & Internet
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
