Everytime I start-up my computer I see these white lines (circle around with red see image below) and my computer takes about 10 minutes to start-up? Is it a monitor or my computer itself problem?
No this is not the problem of your monitor. sometimes it cames while loading operating system. it useually cames when you hybernet your computer.if you dont shutdown and make hybernate then this will appears in next time while you on your system.
Hi, A component called CCD IMAGER is faulty and needs replacement, Basically the component works as an eye to view the image when it start malfunctioning screen and viewfinder does not show image. The detail of said part is given below: Part No. Description 8-753-244-71 ICX611NKF-13 (CCD IMAGER)(HC51E/HC52E/HC53E/HC54E)
For convenience area is marked with red circle in the picture below:
Depending upon the screen resolution that has been set in Display, the image will be distorted on these wide screen monitors. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle). Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle. When you are satisfied then click apply.
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Okay it is definetely the Computer. If lines like that occur it looks like a corrupt system file. I wish i could help you further but i specialize more on FPD problems.
If you have software that changes your boot up picture, it might have made the image you are describing. Thats the only thing i can think of.
Theres software such as WindowsBlinds(just and example) that do these kind of effects.
I hope this helps you get closer to your solution.
it will appear because you did not shut down your computer properly,try to consult to computer technician so they can fixed your computer,its not the monitor its the cpu.
that status line was designed together with your OS, it seems that your PC was getting slow in boot..
A number of factors, having little to do with the age or capabilities
or your system, can create excruciating system slowness. They include
the following:
Operating System File System (how you've organized files on your PC) Applications Hardware
The
Windows OS (operating system) is notoriously inefficient, which can
affect performance. The file system also impacts Windows and hardware
performance. How you work with applications can improve system speed,
as can some basic hardware updates.
