Question about Goodman Heating & Cooling
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Posted on Oct 05, 2011
Posted on Oct 06, 2012
    Genius:
  • 1,015 Answers
I would try changing flame sensor. This should be located right above burner and if it does not register that burner is lit it will shut power off to gas valve. Hope this helps. Thanks
Posted on Nov 13, 2010
Maxx heater lights all burners for aprox 20 sec blower fan starts flame goes out flame lights again for 20 sec never blows much heat ?
sounds like its not getting gas fast enough to keep burning,that happen to me and the gas line was to long of a run for enough gas keep coming. so I up the pipe runs real good the flame keeps burning, so you know you can only go 25 ft in half inch pipe then u lose your flame
Oct 24, 2014 | Mr. Heater Natural Gas Garage Heater -...
10 year old DCS Oven does ignite. Oven ignitor glows but maybe not enough to trigger LP from being introduced?
just because the ignitor glows it doesn't mean it's good,it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,usually if the flame doesn't ignite in around 40 seconds the ignitor is bad.also check the burner tube,your model number doesn't come up so i don't know if you have one or two ignitors in this oven but i've found that when the ignitor starts to fail and the customer waits to long to have it looked at the ignitor burns a hole in the tube and then both the ignitor and tube has to be changed,hope this helps and good luck with your oven.
Jul 19, 2013 | DCS RGU-486GD-L Range 48", 6 Burner,...
Flame turns off rematurely
That is normal. The gas does not stay on constantly. That would burn the clothes. The gas assembly is controlled by a Klixon mounted on the blower housing. As the air comes through the blower The Klixon also known as the cycling thermostat judges air temp and turns the gas assembly on and off. Here is a video explanation:
Jul 20, 2012 | GE Dryers
Blower on.has flame then click. flame off and starts over. every 2-5 sec
Hi clean flame sensor /jump out pressure switch see if it lights check hot surface ignitor is glowing /check and clean air filter
Jan 26, 2010 | Heating & Cooling
York Diamond 80 furnace (propane conversion), about 1998 model. Solid Ignitor comes on, but no flame. Main fan works for about 90 seconds then cuts off. Fan only switch on thermostat does the same, fan...
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Dec 28, 2009 | Heating & Cooling
Dryer runs ,heats up flame goes off after 30 secs won't relight
Seems to be a problem with the bas valves....you shouldve seen them in front of ignitor...will show similar signs of ignitor. part#306106 AND 306105. come off easily with a few screws and just slide over valve assembly.
Jun 08, 2009 | Whirlpool LER4634J Electric Dryer
Heater lights fan comes on flame goes out
There is a flame sensor located in the same area as the ignitor (usually on the other end of the burners). remove the flame sensor with the power off. Then use steel wool or light sand paper to clean the silverish end. Reinstall the sensor and ToDA you are done! Best of Luck!
Jan 29, 2009 | Goodman GDS80904BNA Open Flame Heater
I have a problem with my heating system. It is about 10 years old and has had the ignitor, combustion blower motor, and programable thermostat replace in it's lifetime. The system worked great last year....
sounds like its not proofing flame. it has a sensor usually like a needle sticks out into the flame that tells the gas valve the flame lit and is burning so its ok to keep sending gas, if its fails to proof flame then burner shuts down, then it tries to relight 3 times then locks out on fail safe. the blower will sometimes run continually once that occurs to highlight a failed condition. every time you reset it will try again 3 times then shut down. lp gas is very dangerous, even i do not work on it as the gas acts like gasoline and lays around. not like natural gas that disperses well. if you see the flame sensor try gently cleaning it with a little emory cloth. also a loose ground can cause this. check tio be sure any green wires are snug , they actually flow volts to ground through the flame on some to proof, thats why no ground no flame. if that fails then the board is most likely problem. change wire for wire , or get generic replacemant and follow directions exactly. good luck.some ignitors act as a flamre proofer as soon as they are done igniting! rarely do they fail to perform both funtions.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
331 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
