My armstong "on fan" does not work. model is a
My armstong "on fan" does not work. model is a G1D91BU. when i move the thermostat to "Fan on" it does not run. I get heat and cooling.
    Genius:
  • 1,015 Answers
If it works on heating and cooling but not on fan on position I would reccomend you change thermostat. Hope this helps. Thanks
Posted on Nov 13, 2010
Cannot get ANY of the fans to work.
one half of the breaker you moved is not making contact in the panel or moving the breaker caused the fan relay to be on the same 115 volt leg as the power leg. If the breaker is connected to two points in the panel and you have 115 volts on each side of the breaker (230 volts) You can move the breaker one notch higher or lower or switch wires on the breaker to correct the circuit.
Oct 12, 2014 | Heating & Cooling
Just moved in to new house with central air. Despite turning all 3 zone thermostats to off (ie no cool, no heat), there is still air being blown through vents throughout the house. (fan switches are also...
You should not have the blower fan running if all thermostats are set as you say. You either have a relay problem in the air handler or the zone system wiring or controller is defective.
Sep 01, 2011 | Honeywell Heating & Cooling
Hi, Vulcan " burwood " gas space heater.I have
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
May 19, 2011 | Heating & Cooling
Heil heat pump the outside unit is rattling severly when it kicks on and isn;t blowing warm air, just had an ice storm today, will ice in the unit cause this? also what is the "em heat" selection...
There is ice built up on the fan blades and they are out of balance so they do not move any air....you will need to melt the ice off of the fan for it to work...
The "EM Heat" is to bring on the electric backup heat coils if you have them... you could use that temp. but it will cost you more $$
heatman101
Feb 02, 2011 | Hardware & Accessories
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
Thermo set "heat" and "Auto
Check the fan relay. These relays are used to cut the fan on and off when the thermostat is set in the air conditioning or heating mode or when you move the thermostat to the "Fan On" position. The low voltage usually the green thermostat wire is wired to terminal #1. The low voltage common wire to terminal #3. One line voltage wire is attached to terminal #4. The high speed blower wire usually black is attached to terminal #2. When the thermostat calls for air conditioning or "Fan On" the 24 volt coil is energized, the terminals 4 and 2 close. This causes the fan to come on in high speed. When your home cools down and the thermostat cuts the air conditioner off, the low voltage coil terminals 1 & 3 are denergized, and the fan goes off. Sometimes these little relays stick which causes the fan to run all the time or will not make good contact, which causes the fan to not run in the "Fan On" or air conditioning mode.
Nov 16, 2010 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
