Question about Buck 31" Granite Vanity Top for Vessel Sink - No Faucet Drilling - Highly Polish
Existing vessel sink is stuck to polished granite vanity top. We want to replace the sink with a different one but can't get the sink to release--we originally used silicone adhesive and have tried wedging a putty knife under to cut the bead but it is not releasing, any ideas?
    Genius:
  • 1,015 Answers
Silicone is an excellent adhesive once it is fully cured. I would not try to pry it off but I would suggest that you take the blade out of drywall or utility knife and carefully try to cut through it. It probably will take several cuts to get the old basin free but thats the only way I can think of to do it without damage to counter top. Hope that helps. Thanks
Posted on Nov 13, 2010
Need assembly instructions for kokols pedestal combo sink in clear
Is this any help?
https://sites.google.com/site/bathroomfurniturevanitysink/installation-on-vanities/glass-vanity-set-up-guide-kk09
Otherwise you could send them an email:
http://www.kokolsinc.com/pages/contact-us/
Apr 20, 2015 | Kokols Clear Vessel Sink Pedestal Bathroom...
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
Engineered stone (Silestone) quartz double sink vanity. I need to cut it in half. Need help with what kind of saw, technique, etc.
You are going to cut a double bowl vanity top in half and use the 2 sinks? Do you have enough room on each side for the tops to be at least 24" with the bowl in the middle? You need a diamond saw, water cooled, a skilsaw will work with a diamond blade and somebody hold a hose on it while it is cutting, it would be better to find somebody, a granite top maker with a bridge saw to cut it for you, nice and straight. Then polish the cut edges that show. That stone you have is a pretty tough stuff, you can polish it easier than granite, and it cuts easier, but you still need the diamond, I wouldn't use a dry blade or a carborundum blade. Hope this helps.
Jun 11, 2010 | Home
How do you care for a granite vessel sink? What
need to seal every few years---granite is like any other stone its porous and can be stained by dye products and certain oils
Apr 08, 2010 | Stone DeNovo Absolute Black Granite ...
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Vessel sink drain causes poolin of water.
YOU ALSO HAVE A VENT ISSUE, THE VESSEL SINK DOESN'T HAVE THE LITTLE HOLE IN IT LIKE A VANITY SINK, THERE FOR THE WATER IS GOING DOWN THE DRAIN BUT THE AIR CAN NOT COME OUT, YOU NEED TO INSTALL A STUDOR VENT OR AN INLINE VENT INTO THE DRAIN BETWEEN THE WALL AND THE TRAP CUT IN A TEE AND BRING A PIPE UP TO THE BOTTOM OF THE COUNTER TOP AND INSTALL THE VENT, USALLY HAVE TO PUT A FEMALE ADPT ON THE TOP OF THE PIPE THE VENT COMES WITH THREADS DO NOT GLUE IT IN PLACE, THEY HAVE A RUBBER FLAPPER THAT OPENS WHEN THE WATER IS GOING THRU THE DRAIN AND ALLOWS IT TO PULL IN AIR THEN THE FLAP CLOSES WHEN NO WATER IS RUNNING TO KEEP THE SEWER SMELL OUT
May 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
Pegasus granite, black kitchen sink, rough on the bottam
As a plumber I have seen this problem many times.
A very simple solution!!!!!!!!!
Turtle Wax or any kind of granite counter polish. CorStone (sp?) used to send me a polish/wax that worked wonders but I havent delt with them in a long time so I dont know if it is still available.
Just use try Turtle Wax but make sure not to get Turtle Rubbing Compound as that has grit in it which will scratch the surface of your counter.
Hope this helps.
Apr 12, 2009 | Pegasus Technologies Pegasus 25 In. Black...
Wrong product on granite surface
Contact the company on the bottle! I would also talk to the store manager there as well. The manufacture will give you the correct steps in removing the product. You could also contact an installer and get some ideas as what can be done to either fix it or remove it. Either way, be careful. Most people don't realize that granite can be damaged.
Mar 30, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Granite vanity top
if this is real granite ,check with a local monument or tombstone supplier in your area and ask if they will sell you a small amount of polishing compound , if this is not possible a regular grit toothpaste will work but will take way more rubbing , take a small amount on handkerchief use the tip of your finger rubbing a while then take dry rag such as small towel and buff , repeat until gloss is back or your finger is to sore to continue , tomorrow again . ps make sure it is granite and not plastic
Dec 08, 2008 | Granite CamKiosk Gray Hand Sink Cart
Buck 31" Granite Vanity Top for Vessel Sink - No Faucet Drilling - Highly Polish Logo
219 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
