Question about IBM IntelliStation Z Pro 6221 PC Desktop
Windows Xp on Intellistation Z Pro type 6221
Hi I am trying to repair my corrupted Windows XP Pro installed on my IBM Intelliststion Z pro type 6221. I've got 3 SCSI HDD using the onboard SCSI controller LSI1030. During Windows setup and after pressing F6 to install the SCSI driver I am getting this message "unexpected error ( 4096 ) in line 2113 d:\xpsprtm\base\setup\oemdisk.c
Can you give me an advise on how to resolve this issue..
Thank you very muchh
  • 1 more comment
  • SteadyReady Jun 18, 2008
  • Lee A.
    Lee A. May 11, 2010
    Are you booting up from a floppy or cd?
    Thanks,
    lee
  • Lee A.
    Lee A. May 11, 2010
    Are you booting from a floppy or?
    Master:
  • 377 Answers
A restoration disc is not a conventional Windows OS disc (and vice versa), therefore it often cannot be used as if it were a true Windows disc. The restoration disc includes the OS, but it also includes every driver and other software product that came with your system. If Windows were the only item loaded on your system, then a Windows disc could serve as a restoration disc, but these days, using a typical restoration disc is an all-or-nothing process.
A restoration disc is your ultimate troubleshooting tool. Suppose that your copy of Windows becomes damaged from a virus or key applications become corrupted. Symptoms such as instability, crashing, indecipherable error messages, and impaired performance are extremely hard to diagnose by yourself—even if you have the help of a customer support technician on the telephone. If the most common corrective steps fail, you can always use the restoration disc to recover your PC back to its known-good, factory-fresh state.
Posted on Jun 18, 2008
I have IBM Intellistation Z Pro 6221. I tried to install XP, I press F6 for SCSI driver. Then It prompts Press 'Enter' for install or 'R' for repair. Whatever I press it displays No hard disc detected
You need a floppydisk including the Driver for the SCSI or Sata drive - Depending which HD You are using.
If the controller is in motherboard You will find the driver from motherboard webpages.
If it's a separate controller card - You will find it from it's web pages.
XP doesn't support too well sata if it's not the XP SP3 version media.
You may need to change the sata to compatibility IDE mode to get it up and running.
Jan 06, 2011 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM IntelliStation Z Pro 6221NNG upgrade possiblity
This: http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx is a link to the system requiements. As for memory, I can't find out if it's DDR or DDR2. If you don't know either, try downloading a tool called CPU-Z. That should display DDR or DDR2, and I can then recommend something.
As for the graphics card, you could try to get an ATi 9000 series card somewhere.(maybe buy one on ebay? I doubt they still sell them new...) I have one too, in an old PC, and while it doesn't run any new games, it's fast enough for the casual user.
Dec 07, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
How to install Adaptec SCSI driver when installing XP -Z Pro 6223
you have to use sata xp cd to intall that driver no need floppy disk.
Aug 19, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Intellistation Dreaded "ntldr not found"
You have the solution given the fact that the IBM netloader wants to be subordinant to a loaded OS on a different drive acting as server when used on a thin client like the Intellistation. Unless carried as a portion of the registry of an MS OS, XP or Vista will drop it unless registered with a NetUpdate as a standing part of the registry. But most sysops conduct updates without all clients active so that some will inevitably be dropped, which is why the best strategy is to conduct updates on Off Hours when all clients can be up without human interaction, impossible during the workday, unless you deactivate an entire set of nodes for the purpose.
Run a reregistry while the Intellistation is on and active but without an operator and your problem should disappear more permanently.
Apr 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM IntelliStation Z Pro 6221 PC Desktop Logo
986 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
