Question about Kenmore 22422 Top Load Washer
How do I get cover off my kenmore washing machine before my father breaks it:-( its a top load and won't spin.
    President:
  • 1,654 Answers
The top control board has two screws I believe. Remove them and tilt it back, this should give you access to the screw that hold the cover on. The cover is one piece and it removes from the front. You don't have to unhook the machine and when it comes off it will give you acces to the drum and motor underneath the drum. Check the motor/transmission coupling, these tend to go out. The good news is it is not expensive to fix if this is the problem, you also want to replace the plastic tabs in the agitator because these wear out about the same as the coupling and they are also very cheap to replace. If you have to have someone fix it it should only cost around $100.00 total with parts and service call if that much!
Posted on Nov 13, 2010
  • Dcramer531
    Dcramer531 Nov 15, 2010
    http://i160.photobucket.com/albums/t200/... then click this one:----http://i160.photobucket.com/albums/t200/... then click this one:---http://i160.photobucket.com/albums/t200/... --------- Then click this one:---http://i160.photobucket.com/albums/t200/... --------
    Some of these machines have clips in place of screw and the end caps must be removed to get to these.
  • Dcramer531
    1. .Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. 2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up. 3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove. 4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier. 5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand. 6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple. 7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly. 8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position). 9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly. 10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped). These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Washing machine won't spin, drain, or wash
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 22, 2011 | Kenmore Washing Machines
Water will not drain out of the washing machine and won't complete cycle.
heatman101
Sep 10, 2011 | Kenmore Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Why won't my washing machine spin?
heatman101
Aug 13, 2011 | Kenmore Washing Machines
Washer will wash but won't spin or drain
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
My washer won't spin and drain. what should I do?
heatman101
Aug 09, 2011 | Kenmore Washing Machines
Model no. 23832, won't spin, lid switch is good and so is motor coupler. HELP
heatman101
Aug 09, 2011 | Kenmore 2383x
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Kenmore 22422 Top Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
