Question about Bosch Classixx WFL 2462 Front Load Washer
Door can not be opened cos the spinning function does not work
Check the water level switch. If the tube is blocked, than the membran inside can't see the pressure. door can not be opened cos the spinning function - pressureswitch1.jpgIt's looks like this. Some machine's have more than one and some have more contact's which means that they can measure more than one water level. In most cases you have to take off the top cover of the machine to locate it. Take off with care the tube and blow towards the pump to remove a block.
To test the water level switch you need a multimeter in resitance Mode ( Ohm) to measure the contacts of the switch. If you gentle into the switch you can hear when the membran switches the contacts - on the multimeter you should see a change ( 0 if contact is closed - 1 if the contact is open). If nothing happend then the switch is faulty and have to be replaced. DO NOT TURN THE SEALED SCREWS on the switch. I hope this could help.
The picture is copied from this website : www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Posted on Nov 21, 2010
Sin, cos,tan don't work. For example, I click 1, 2nd and cos and I'm getting 1 instead of 0.54. In all other buttons the 2nd function is working but not for sin, cos, tan. Thanks for any help!
I wonder if your calculator is set to the wrong units. Your calculator can be set to degrees, radians, or gradians. I assume that you want it set to degrees.
When I click 1 2nd and cos, I will always get 0, because using the 2nd before the cos turns the function into cos^-1 (inverse cosine). The inverse cosine of 1 is 0 because the cosine of 0 is 1.
Good luck.
Let me know if you have any further questions.
Paul
https://education.ti.com/en/us/guidebook/details/en/ADF11FB65B284B6195B0A7E9502784BA/baiiplus
Dec 20, 2015 | Texas Instruments BA II PLUS Financial...
Changed door handle but door still won't open from inside
which door is it cos rear doors have a kiddy lock-when you work the handle can you feel any resistance,as if the handle is actually connected or is it 'floating' ?
Jul 06, 2012 | 1998 Toyota Corolla
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
How to solve for the trigonometric functions in the casio scientific calculator?
Press the relevant function key [SIN],[COS],[TAN] followed by the angle value.
For inverse trigonometric functions [SIN^-1], COS^-1], or [TAN^-1], Press [SHIFT][SIN], [SHIFT][COS], or [SHIFT][TAN].
For other functions
sec(x)=1/cos(x)
csc(x)=1/sin(x)
cot(x)=1/tan(x)
When calculating trigonometric functions one must make sure that the angle unit the calculator is using is the correct one.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
Why the cos of 90 is -0.44... ?? and the tan sin its'nt correct in the calculator what can i do ?
The trigonometric function evaluations depend on the angle unit you are using: degree, radian, grad
While cos(90 deg)= 0,
cos(90 rad )=cos(90* 180/pi degrees)= -.448073616
ALWAYS CHECK UNITS before using trigonometric functions or their inverse functions.
May 13, 2010 | Casio FX-7400G Plus Calculator
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
Cos+tan(sin)=sec
This is a trigonometry problem not a calculator's.
cos(x) +tan(x).sin(x) = ( cos(x) + (sin(x)/cos(x)).sin(x). After reduction to the same denominator (which is cos(x)) you obtain
{cos(x).cos(x) + sin(x).sin(x)} divided by cos(x).
The content of the bracket above is just 1.
Your fraction will have 1 as numerator and cos(x) as denomitor. That is exactly the definition of the secant function i.e. Function sec is the reciprocal (not the inverse) of the cos function, while the arccos is the inverse of cos.
A mild advice: Avoid writing function without specifying the argument (the variable on which a function acts).
Note:
Aug 14, 2009 | Casio FX-115ES Scientific Calculator
How to get cos, what order keys
Each of these are function keys. Press the key and the display will show the name of the function followed by an open parenthesis. Enter a value or expression for the argument and close the parenthesis.
Jun 13, 2009 | Texas Instruments TI-83 Plus Calculator
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
TI-84 Plus silver edition sin/cos/tan
for function = (sin,cos,tan,sec,cosec,cotan)
arc(function) = function^-1, calculated in the first quadrant for simplicity(0-pi/2) (0-90deg), as all functions repeat circularly
just another method of notation
http://www.mathwords.com/t/tangent_inverse.htm
Jun 19, 2008 | Texas Instruments TI-84 Plus Silver...
Bosch Classixx WFL 2462 Front Load Washer Logo
26 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
