Question about GE Ovens
My GE Electric oven is not heating fast or getting upto full temperature. Model No. J BP76G V2WW
  • Dave Jansen Nov 13, 2010
    THANKS!! is the thermostat easy to get to??
  • GE Master
  • 1,711 Answers
Your model has a thermostat composed from two parts. One is the temperature probe part no 248 Sensor kit
Part Number: AP2023913 made by GE
And the electronic control which is one part with electronic control board part no 16, To8c, Electronic control - Wiring instructions are not included if new part does not match wiring a appliance repair person may be needed.
Part Number: AP2632445 made by GE
We suggest first to replace the probe which is the 80% potential suspect for malfunction and a cheaper part and only if your problem insists you need to replace the electronic board.
The above parts and all other parts of your model can be found in the following link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212098&diagram_id=20734924#d20734924
Posted on Nov 13, 2010
  • GE Master
  • 3,051 Answers
Hello there:
This is a fairly common problem with these ovens normally what happens is that you will notice that the temperature will not come up to the proper temp or it takes a long time to heat up
This is caused by the thermostate either being damaged or faulty and not reading the proper temperature inputs from the controle panel so what i would do is to have the thermostate either checked out by a repair man or replace it ti will look like one of these
GE OVEN MODEL BP25G V2WW WILL NOT HEAT
Check the thermal coupler.
Aug 07, 2012 | GE Ovens
Oven is not generating any temperature
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 22, 2010 | GE Profile JTP56 Electric Double Oven
Heats up, gets to certain point and begins to beep(e-3)
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Sep 21, 2010 | GE 30" Built-In Single Electric Wall Oven...
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
When my GE wall oven is in the middle of heating up, I get an F3 edit and the oven keeps beeping. I turned it off and then turned it on again and it seems to be heating again. What part should I look to...
Hello there:
Normally this is due to a bad temperature sensor F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and replace if found faulty
Apr 27, 2010 | GE Profile JK915 Electric Single Oven
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
Dec 26, 2009 | GE JKP15 Electric Single Oven
Lower and Upper ovens not heating
they have a thermal fuse in them that blows if too much heat builds up in them they have an improved blower moter thermal fuze kit for them i suppect thats the promblem contact ge for improved kit and inst ins
Dec 29, 2007 | GE Profile JKP56 Electric Double Oven
GE Double Oven JKP45BA, lower oven wont heat
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Ovens Logo
281 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
