Question about Tools & Hardware - Others
Have lost plug in for a Durabrand DPT359 Rotory Tool. Can you advise where I can get one?
Is there a Manual for a durabuilt electric rotory tool?
Here is a link for a PDF of the Manual for WEN Products electric rotary tool. Their product is very nearly an EXACT duplicate of the no-longer-available Durabuilt electric rotary tool.
I use this manual at home for my Durabuilt product.
http://www.wenproducts.com/store/index.php?route=product/download/download&download_id=62
Jul 02, 2014 | Tools & Hardware - Others
Missing DC 9 volt cord for durabrand 1700 dvd portable player
you make new 9 volt charger purchase new changing pin compatible 1700 dvd player and operate it
May 20, 2012 | Durabrand DUR-1700 Portable DVD Player
Durabrand 7" Portable DVD Player DUR7
The charger=look on side of durabrand where power plug should go.there s/b somethine like [C+] or[ c-]
it is not really the letter C but the symbol of the outer rim of the plug that goes into DVD player.[C+] means that the outer shell of THE PLUG is negative (-) with the INSIDE being positive (+) with respect to a battery. [C-] again, the outer connection is (+) pos., inner connection (-) neg.
Look for power rating, as an EXAMPLE ( 5v at 1.5a [5 volts at 1.5 ampers]
May 22, 2009 | Durabrand DUR-1700 Portable DVD Player
Lost remote for Durabrand DVD- 2005 player
Cinetec (whoever they are hehe) remotes will work the Durabrand
Jan 18, 2009 | Durabrand DVD-1002 DVD Player
Durabrand tv wont turn on!
My Daughter has the same problem with hers. That high pitch noise your hearing is coming from
a transformer on the inside it means the transformer went bad and has to be replaced.I hope this helps a little.
Jan 02, 2009 | Durabrand DU1901 TV
Dvd player hook up
DOES YOUR TV HAVE AUX RCA INPUTS OR JUST A STANDARD ANTENNA CONNECTION. CAN U ACCESS CHANNEL 3 OR 4 ON THE TV..HOW DO U ACCESS UR VIDEO INPUTS. A POSSIBLE SOLUTION IS TO GET A MULTI INPUT SIGNAL SELECTOR FROM RADIO SHACK THAT WILL TAKE THE RCA AND CONVERT TO STANDARD ANTENNA CONNECTION TO PLUG INTO THE PORT
Jul 20, 2008 | Durabrand DWT1304 13" TV
Lost remote for durabrand (dur-7)
I have a remote for sale for $29.99 including shipping to lower 48 states. If interested email me at 1topwop@comcast.net.
warm regards,
Jul 07, 2008 | Durabrand Portable DVD
Charging
You can buy an ac power charger adapter for your Durabrand PDV-702 here:
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Jun 08, 2008 | Durabrand PDV-709
Durabrand dvd
you will need either a scart leed or a set of colour leeds usuall red yellow white plug these itno your player matching the colours up then in the back of your telly you should have the same colour conectors plug these in then press the av button on your telly this should pick up the signal hope this helps you
Oct 16, 2007 | Durabrand DVD-1002 DVD Player
Tools & Hardware - Others Logo
35 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
