Question about West Bend Kitchen Appliances - Others
The bread pan leaks. We need the clip and O ring for the shaft that goes through the bread pan and into the paddle.
    Genius:
  • West Bend Master
  • 1,280 Answers
In my opinion you would be better of just replacing with a new pan as you would pay about the same as trying to locate small parts for your used pan and it still might leak. If you want a link or supplier for your pan just send me the model # of your West Bend....
daryl441@msn.com
Posted on Nov 13, 2010
How do I get spare parts for a bifinett bread baking machine KH1170
Really by the time yo find a part and pay shipping and handling you may be better off to trash it and buy a new machine on sale.
Best wishes
Nov 05, 2014 | Breadman Bifinett Kompernass Bread Maker...
My sunbeam breadmachine started getting the oil spots,leaked into dough and eventually whatever held the paddle shaft onto the bread pan disintegrated or disappeared. Would that be the seal or some kind...
Hi
As long as the drive mechanism beneath the pan is still stiff to turn and fels like it engages the motor you should be fine. See pic. The centre 4 spike drive unit is what is important. Normally the toothed drive belt will fail. If this is still good then replace the pan.3f754847-72d6-45ec-a55c-8ca7f7deffab.jpg
May 29, 2014 | Sunbeam 5891 Bread Maker
Bread pan bounces on paddle rotor during kneading process
Make sure you have the pan snapped in between the two springy clips at the top of the oven cavity. Also make sure you have the pan all the way down on the shaft. If there's something in the hole for the shaft, it won't go all the way down and engage the shaft properly.
Mar 04, 2011 | Cuisinart CBK-200 Bread Maker
I have this machine for 4 years now and I was happy with The central shaft does not turn now and I lost all my stuff... It makes the noise like if it works, but nothing happen... and there is a...
Hi.. The "central shaft" could mean the motor shaft is not turning or the "central shaft" could be the paddle shaft in the bread pan is not turning. If it's the motor shaft then tighten or replace belt. Since you "lost all your stuff" it could be the sealed bearing in the bottom of the bread pan has broken. The paddle doesn't turn and is leaking. If this is the case the bread pan needs replacement. Hank
Jan 18, 2011 | Black & Decker B1561 Bread Maker
Hi, I had all my ingredients in the pan and was bringing it to the machine to begin making bread. When I noticed the liquid was leaking out from the bottom. I had a mess everywhere. Come to find out the...
Hi, The leaking is from the sealed bearing that the paddle shaft rotates on. It wears out over time. It can not be repaired and you will need a new bread pan. Sorry Hank
Nov 23, 2010 | Breadman TR2200C Ultimate Bread Maker
The liquid leaks from the shaft of the bread pan. Upon further investigation, the shaft drops down slightly from it's original position as I can push it back up but it won't stay up. What can I do to fix...
Hi...The paddle shaft fits tightly on a sealed bearing. This allows the shaft to spin freely. Over time the sealed bearing wears out, the shaft gets loose and liquid will leak through. Unfortunately there is no fix for this and a new bread pan is needed. sorry...Hank
Nov 11, 2010 | Cuisinart CBK-200 Bread Maker
The container that bakes the bread has a tab on the bottom that turns, and is on a shaft that goes thru the bottom, and this shaft is held by a snap-ring. we can't get the tab off,(supposed to come off to...
Thank you for visiting Fixya. The tab you speak of is called the paddle. The paddle sits on a shaft that is pressed into a sealed bearing. This shaft is not supposed to move in the bearing. If the shaft moves the bearing will lose it's seal and lubricating fluid (oil) will leak out. The snap ring, bearing, and shaft are put together before they are installed into the pan. If you can't fit the ring back onto the shaft so the shaft doesn't move, then you should hunt around for a new bread pan. P.S. Putting soapy warm water in the pan and letting it sit for a while will free up the paddle so it lifts off the shaft. Also lubricating the shaft with a squirt of olive oil will help stop the paddle from sticking on the shaft. Good Luck...Hank
Nov 28, 2009 | Zojirushi Kitchen Appliances - Others
Shaft falls out on BB280 breadmaker
Unfortunately there are no official spare parts for the bread pan of the BB280 other than the pan and the paddle, I suggest checking with your local Breville service centre to see if they have a circlip that will suffice, or to check that the pan is intact.
May 23, 2009 | Sunbeam 5891 Bread Maker
Circular clip holding paddle axle in place
I fixed this by using an "e-clip". You can get e-clips at any autoparts store, or online in assortment kits for cheap money. You have to remove the spring seal and washers inside the pan, you also have to remove the circlip on the bottom of the paddle shaft, you have to install the paddle from the inside once you have the right size e-clip installed.
It's a lot harder to explain than to do, once you get it apart you'll see how things go together. I have no clue what originally used to hold the shaft in, mine made sqealing noise, when I took it apart there was little left of the original part.
Aug 04, 2008 | Breadman TR2200C Ultimate Bread Maker
Kitchen Appliances - Others Logo
141 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
