Question about Car Audio & Video
Brought a juice ja490 amplifier and it was working but now it isnt its gone to a red light and when i turn my stereo on it flicks from red to blue and my sub makes a popping sound
Mitco39
  • 62 Answers
SOURCE: Subwoofer seem to be broke
The one sub that you described is gone, there should be no reistance at all when you push on them. It sounds like you got your gains set to high on that amp (maybe the amp is underated for your subs). When you turn up the gain to high your cause your amp to distort and it can get as bad as sending a pure DV current to the sub. That DV current will blow subs because of all the force directed in one direction. If you think about it the amp takes a DC current and turns it into a AC current which creates the frequecy (rate at which it alternates) that alternating current pushes and then pulls on the sub keeping it within its boundries.
Posted on Mar 25, 2007
hogan doan
  • 227 Answers
SOURCE: i have just bought a
Try a different speaker if there is no sound then it is your amp output fried. Goodluck.
Posted on Apr 24, 2008
SOURCE: sub works but doesn't sound right
hey been there before u need new rca wires form ur radio to the amp.
Posted on Jan 17, 2009
SOURCE: When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Posted on Apr 05, 2009
  • 45 Answers
SOURCE: Subwoofers pop then immediately produce no sound
Sounds like the two subs wired together might be too much of a load on the amp and it is shutting off. Try wiring the two subs in series. That will reduce the load on the amp but will conversely put out less power. Less is better than none though. In any case check your amp to see what the lowest ohm rating it can see, that ohm rating is where you want your subs and if faced with a choice of either going under (lower numerically) or over (higher numerically) GO OVER!-it is much safer.
Here's an article I wrote that can help explain how to wire the subs to the amp.
OHM LOADS, SUB WIRING, OHM RELATED POWER OUTPUT
SERIES SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the negative pole of the other voice coil (on the same sub). This will leave you with a positive pole from one voice coil and a negative pole from the other giving you the two leads that will be hooked up to the amplifier or other subs. When wiring in series, the ohms will go up numerically, and the load on the amp will go down. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
PARALLEL SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the positive pole of the other voice coil (on the same sub). Then wire the negative to the negative in the same way. You can then wire to the amp or other subs. When wiring in parallel the ohms will go down numerically, and the load on the amp will go up. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
MULTIPLE SUBS USING SERIES AND PARALLEL WIRING
In order to match your amplifiers ohm rating you can use parallel and series wiring together, just keep things even for power distribution and to avoid phase issues.
Example: I have two “Type X 12” subs” that have dual 2ohm voice coils and have to match my “Amplifier X” ohm rating of 2ohms mono. In this case, I would wire each subwoofer in series (giving me a 4ohm load), and then wire the two subs in parallel to get my 2ohm mono load. When wiring multiple subs just, treat each sub as a voice coil and wire accordingly.
POWER OUTPUT AND OHM LOADS
For example if “Amplifier X” can make 100watts@8ohms, it would make 200watts@4ohms and 400watts@2ohms. However with every drop in ohms the amplifier is put under more pressure. It starts to create a lot of heat, distortion figures begin to climb, damping rates drop, and some amps even throw power spikes when clipping. SO BE SURE TO CHECK YOUR AMPS RATING AND DO NOT EXCEED IT!
-Dynami
2001 dodge stratus coup raido wire diagram
i split the diagram in two just prtin and paste. and please leve 4 thumbs up thanks
May 07, 2011 | Dodge Stratus Cars & Trucks
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
I have brought and wired everything up but cannot seem to get the remote to work it keeps saying something about a blue wire but the blue wire that came with my package will not fit the remote
The blue remote lead hooks up to your stereo head unit in the dash...when you turn the radio on the remote lead becomes hot(+12V) to turn the amplifier on...without the remote lead the amplifier would stay on all the time and would then drain your battery...the blue lead is a turn on signal sent tot the amp
Jan 20, 2011 | Fusion FEW12PK Car Subwoofer
Stereo wiring harness need to the colors and what they do? for a 1997 mercury mountaineer
cannot find 97 but found 98. Do these match?
1998 Mercury Mountaineer Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: 6? x 8?
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1997 Mercury Mountaineer
What is the stereo wiring diagram for 1997 ford explorer xlt,and does it have an amplifier?
1997 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Front Speakers Size: N/A
Front Speakers Location: N/A
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
and im not sure if it has an amp but it has the triggger wire
pls rate
Aug 16, 2010 | Car Audio & Video
100 watt dhd amp wont turn on
If it's an aftermarket stereo, there's a small blue wire (accessory/antenna) that goes to the amp. So in essence, you have the large cable going to the battery that powers the amp. However, the small power wire going into the amp tells it when to turn on, by the stereo.
Mar 09, 2010 | DHD NTX-2004 Car Audio Amplifier
Wiring diagram ford f350 04 for radio need color codes
2004 Ford F350 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Stereo Antenna Trigger: Blue
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Blue/White
Left Front Speaker Negative Wire (-): Orange/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
Right Rear Speaker Positive Wire (+): Brown/Pink
Right Rear Speaker Negative Wire (-): Orange/Red
Jan 04, 2010 | Car Audio & Video
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
Car Audio & Video Logo
114 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
