Question about Poulan Garden
Poulan 2150 Woodman Chain Saw When I release the throttle(idling), the chain doesn't stop.Shouldn't it stop for safety reasons? I don't have the maual.
  • 2,926 Answers
Yes, the chain should stop. There is a metal ring inside the chain housing cover that either broke in half or cracked off the mounting location.
Posted on Nov 13, 2010
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
FUEL MIXTURE SCREWS BEEN ADJUSTED IMPROPERLY. WHAT IS PROPER HIGH -LOW CARB SETTINGS FOR 40CC POULAN CHAIN SAW
Make sure the air cleaner is not plugged. Turn both jet screws CW to stops (lightly), then back each out 1-1/2 turns CCW. This is a basic setting and should allow the engine to start and run. When the engine is warmed up, pull the throttle full on and adjust H jet needle CW until the engine starts to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L jet needle CW until the engine idles fairly well, but the engine should 'follow the throttle'. It will tend to 'gasp' when pulling the throttle if you have gone too far. Idle speed screw should be set so that the chain doesn't try to turn, but the engine continues to idle. Hope this helps!
Jan 04, 2011 | Poulan Pro Chain Saw 46cc 20"
Chain won't stop when throttle pressure is released.
Start the engine and allow to warm up. Turn the idle speed screw (not the jet screws) CCW to reduce engine speed until the chain stops even hinting at running. If you get it too low, the engine will tend to die when it idles. Hope this helps!
Nov 25, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I have a Poulan 2150 chain saw which needs a new chain oil pump. What is the cost to replace it. Should I just buy a new saw.
If you perform the labor repair likely <$20 (<$9 for pump, <$1 worm gear). Compare replacement cost to 34cc± replacement, your call.
A link to a Poulan 2150 Gas Saw Type 7 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2150-Gas-Saw-Type-7/75.2150-Gas-Saw-Type-7.1.59.1.html
If the link is not your saw it can be found here.
The IPL (exploded parts list) for your saw is the only detail for the oil system and it is sketchy at best. Oil components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The oil pump is under the outboard clutch, this is helpful with removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Poulan Pro Chain Saw 46cc 20"
I have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Carburetor initial adjustment for Poland 2150
Both about two turns or so. Engine must be warmed up to properly set the running adjustments. H adjustment to get four-stroking with no load, but immediate smooth out with light load (cutting wood). Idle set for smooth idle, but allows immediate pickup from idle when throttle applied.
Jul 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain keeps turning while in the idle position . Poulan Pro 2075 chain saw.
There will be an idle (Low) speed adjustment screw somewhere on the saw (look in your manual). Adjusting this setting lower will prevent the chainsaw chain from turning in the idle throttle position. Basically you want to set it so the chain has just stopped moving... but you need to set this after the chainsaw has warmed up a little.
Mar 13, 2009 | Poulan Garden
Engine stalls
Sound like the clutch is not disengging. The springs in it are likely week. Take note as to weather the chain stops when it is idleing. If it seem to idle at a reasonable speed and the chain does not stop turning, the clutch is most likely the problem. This problem can be caused by trying to work the saw without the throttle wide open. When the clutch slips it creates heat wich will over heat, and weeken the springs used to disengage the clutch. It is also possible that it was defective when new.
Jan 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2375 poulan chain saw brake is shot,how do I fix it?
You Likely by this time have resolved this. Mine messed up one day and I found a spring inside it. This spring wraps around the counter weights and pulls them together at idle speed, allowing the chain to stop, without stopping the motor. As you throttle it up and the RPM increases the spring allows the weights to push outward , engaging the chain. I have used mine without it, but I'm sure that would not be a recommended procedure, as the chain is always engaged, even when idling.
Oct 06, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
135 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
