Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Have a whirlpool conquest the main board has a relay clicking on and of and the fridge will not cool after a while
    Guru:
  • 1,524 Answers
Change the main board available Bi Coastal Appliance Parts 1-800-673-1262
Posted on Nov 13, 2010
Testimonial: "thx for the help ! boards on the way will get back if it works"
Where can i find a wiring diagram for whirlpool control board w10135090?
Normally unit technical sheet is hidden for technician reference inside the front bottom kick plate or just under it. Please put it back after using it to the right place. Next guy working on your fridge need to refer that.
Sep 03, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Side by Side (33 inch across) Lights work, but neither side is cooling. No compressor running.
it's either in defrost mode and the timer is stuck, or the relay or fuse is shot on the main board. might also be the thermostat. find the timer (usually under the fridge near the front). there will be a dial on it- turn it to see if the compressor comes on. if it does not, check the main board (also underneath, but towards the back).
Nov 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights in fridge side are all out. After changing bulbs, sounds like a relay sticking and will knock out all lights in fridge unless we loosen off the bulbs in the fridge side
your main control board Part#4334000 is defective in lower left rear of unit remove it from the white plastic box and underneath it will have a burned spot on the printed circuit trace get it at appliance parts pros 1-877-477-7278
Sep 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My fridge stoped cooling
Sounds like you are describing a capacitor. And the relay that is attached to the compressor is called a PTC relay.
Jan 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest
hi thanks for the question when you say it short cycles that's the compressor relay trying to start the compressor i would replace the relay & overload at the compressor thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
163 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
