Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Installation program for seagate gone - Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
  • 29 Answers
Download from seagate official website,sir
Posted on May 05, 2009
Using Seagate Goflex Hard-drive 750 GB, upgraded Windows 7 to Windows 10. get message Seagate harddrive not supported on Windows 10. Is there a solution to fix this? Russ
Will My Hard Drive Work With Windows 10? - PC Magazine
www.pcmag.com > ... > Windows 10
PC MagazineJul 29, 2015 - Some drive manufacturers have gone through the Windows 10certification process, ... Seagate products are NOT compatible with Windows 10.
Seagate GoFlex not compatible with Windows 10 - Microsoft Community
answers.microsoft.com/.../windows/.../windows_10-hardware/seagate...n...
Aug 4, 2015 - Since, the Seagate Dashboard is not compatible with Windows 10, let's try ... 10 with my Seagate FreeAgent Go Flex Home 1T external hard drive - model ... Windows 10 Backup Not recognizing Seagate Desk External Drive ...
Aug 18, 2015
Windows 10 Install- Now Seagate External USB 3TB HardDrive ...
Aug 13, 2015
Seagate 3TB external hard disk not working with Windows 8 ...
Jan 26, 2013
More results from answers.microsoft.com
Dec 16, 2015 | Seagate Computers & Internet
Not working in PC
You got to connect the Segate drive to the computer you launch the program from...
Aug 26, 2014 | Computers & Internet
Seagate backup plus is beeping and will not pull up on computer??
Troubleshooter: Seagate Manager does not see my Seagate FreeAgent drive Troubleshooting in case the Seagate Manager cannot detect the FreeAgent drive.
Sometimes, Seagate Manager (the software bundled with newer FreeAgent drives) does not see the drive.
This article focuses on drives that can be seen in Windows, but are not seen in the software.
If you are using Windows 8, please note that Seagate Manager is not supported in Windows 8, so you will need to use a different backup solution.
If the drive is not detected in Windows 7/Vista/XP, then use the external drive troubleshooters to try to resolve the non-detection issue.
After connecting the FreeAgent drive, please give it up to 1 minute to display in the middle of the main screen in Seagate Manager.
If the drive does not display, open My Computer (Computer for Vista) and confirm the drive is listed there. The drive should be listed as "FreeAgent Drive". If you have formatted or renamed the drive, then it will show up with the name you provided.
If the drive does not display in My Computer (Computer for Vista), use the External Drive Troubleshooter to help resolve that issue before continuing.
If the drive is detected in Windows, check if the Seagate service is running.
  1. Right-click on the My Computer (Computer for Vista) icon.
  2. Choose Manage.
  3. In the Computer Management window, click Services and Applications.
  4. Open the Services area.
  5. Scroll down the Seagate Service (they are listed alphabetically).
  6. The Seagate service should display Started in the Status column.
    If it does not, right-click on the service and choose START.
  7. If the service reports as Disabled, enable it to start automatically.
    To do this, right-click on the service. A Status Type drop-down menu will appear. Click on the General tab. Select Automatic and click OK.
  8. Reboot the computer.
  9. If the service fails to start after you reboot with these settings, then check the logs of your Antivirus or Antispyware software to confirm they are not restricting the startup of this service, as some aggressive protection programs can prevent services from starting until you approve them. So, you may need to approve this program specifically in the Antivirus/Antispyware software. Please contact your anti-virus software support for help.
  10. If the service will not start or is working already, uninstall the software (for steps on uninstalling the software, see this article).
  11. Once the software is uninstalled, reboot the computer.
  12. Then reinstall the software by opening the InstallSeagateManager.EXE file on the FreeAgent drive. If you have removed the software from the drive, it can be downloaded from the download center.
  13. If the drive is still not seen by the computer, connect the drive to other USB ports on the computer.
    Some eSATA cards block the drive's identity and prevent it from working. Updates have been made to Seagate Manager and to some vendors' eSATA drivers to help this issue. See our eSATA tips article for details.
  14. If the drive still does not display after these steps, please contact Technical Support.
Check Required Windows Component Installations
1. Check to make sure you have the MSXML Parser 6.0 installed:
  • Open Control Panel
  • Open Add/Remove Programs / Programs & Features (Vista)
  • Check box for "Show All Updates"
  • Look for "MSXML Parser 6.0"
If this is not found, visit Microsoft's website to install this component: http://www.microsoft.com/downloads/details.aspx?FamilyId=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
2. Make sure Microsoft .Net Framework 3.5 installation
  • Look for "Microsoft .NET Framework 3.5".
If this is not found, visit Microsoft's website to install this component. 3. Try the steps listed here.
4. Remove the Seagate folder from C:\Documents and Settings\All Users\Application Data (XP) or C:\Program Data folders (Vista) and reboot.
5. Download and install the newest Windows Installer.
6. Download newest Seagate Manager from our Website and re-install a clean copy. Note: Do not do the update when the message pops up saying one is available.
Jul 24, 2014 | Seagate Backup Plus 500GB 2.5" Blue...
Runtime error abnormal program termination
Sounds like you have ran a scan on your drive and the software has become corrupt.
Download the utility from Seagate and try again
Feb 08, 2014 | Seagate Back Up Plus Desktop Drive...
How to backup files and folders
did you install the software included on the seagate?
if not install it and you can setup the back up/schedule.
or you can use windows backup to schedule backups to the seagate drive.
Mar 05, 2011 | Seagate FreeAgent Pro 500GB External USB...
Cannot format a sata drive completely, i have installed a new master hdd which is 500GB, however when formatting I can only see 128GB
Check drive for partitions. Also, you can use a program such as Seagate DiskWizard to format and setup for loading. That program is available from Seagate's web site.
Jun 17, 2010 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Installing Win XP to my new seagate HDD but cant complete kept on going to install process and cant boot unless boot to CD thats why it keeps on going back to installation process, what is the problem why...
Have you tried replacing the ribbon cable? Did you remove the jumpers off the back? if no to these to then Get a windows boot disk and Fdisk the drive and reformat then install the system. When you do the proceedure above say good by to any files they will be gone. You could have a boot virus that is causing your problem. hope this helps.
May 29, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My stepson said that he "re-formatted" my new Seagate Free Agent USB 2.0 500 gigabyte desktop drive on my MAC. So, now when I plug it into my computer I don't see any icons or anything? I don't know what...
If the Seagate has been re-formatted, then you will have to go through the re-install of the drive to your MAC, the drive should have come with it's own formatting tools and drivers. These external drives usually respond better with a small program that installs a set of driver tools. If you do not have the original freeagent disc, go to the Seagate support page, look up the model of the drive and download the program and drivers for that model and version.
Nov 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Delete data from drive K on Seagate Free Agent PRO
Hi there! In order to solve your problem, just go to System Restore and restore your computer the date during you installed the Free Agent Pro, then try to re-install the application after the system restoration.
Nov 03, 2007 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
83 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
