Question about Garmin nuvi 350 GPS Receiver
Nuvi 200 'Updating GPS Firmware 1%' Problem
Nuvi 200 - goes into repetitive cycle of 'Acquiring satellites' - 'Updating GPS Firmware 1-100%', GPS Firmware Update Complete', then back to 'Acquiring Satellites' and repeats cycle.
GPS is not usable in this state. The one day it was fine, next day like this. There was no upgrade of either firmware or software inbetwee.
I have
i) Updated the firmware with and without memory card present.
ii) Reset the unit.
Zero result.
Please help!
  • Anonymous Mar 22, 2014
    It will not aquiren an satelite.
  • Garmin Master
  • 13,433 Answers
Hello
The device needs a good reset and a full reinstall.
You might not be able todo it at home, If you connect the device into your pc, copy all the internal files from there into your harddrive, every folder one by one, few folders will be locked icnore this. Ones all the files and folders have been copyed.
Format the gps disc, after format is done copy the folders back you might also need to copy the files in the root back. thats optional in my opinion.
Ones that is done, you might have to reset and restore firmware again.
if this doesn't solve this contact garmin and get it replaced or repaired.
I've done this with another customer, he didn't report back or complain it must have worked.
Posted on Jun 18, 2008
  • Ekse Jun 18, 2008
    We did this on a TOMTOM yours is garmin, might not work on yours.
  • 4,472 Answers
Sounds like you did an incomplete firmware update. Go here:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp and update it manually.
Good luck.
Keep me posted,
Lee
  • Lee A.
    Lee A. Jun 18, 2008
    There are alot of the same issues with alot of these. You might want to think about upgrading but first try the website and see if all the steps are correct.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 19, 2008
    If you still need help please let me know. If not I'll assume you found your solution. If you do get a chance and you found any of this helpful I hope you will accept a solution and rate it accordingly.
    Thanks,
    Lee
    Sergeant:
  • 243 Answers
There is actually a problem lots of people have with this unit and it seems in the FAQ i can find through garmin that it can take up to 30 minutes to aquire the satellites. there is no fix but if it has the option to get a additional antenna i would try so. If not id suggest a new unit.
  • Nathan Ayers
    Nathan Ayers Jun 18, 2008
    i dont know if my answer went through but ill try again.
    there is actually a problem lots of people have with this unit and it
    option to get a additional external antenna i would try so. If not id
    suggest a new unit.
GPS Firmware Upgrade Popup
Easy problem to repair. Please see this link for repair assistance.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
May 28, 2010 | Garmin nuvi 350 GPS Receiver
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 - continually updates firmware
I can help you fix your Garmin Nuvi 200W. You will find the newest version WebUpdater if you follow my links, released March 31, 2010. I think you will find between a Hard Reset and the new software, your Nuvi will be better than new again.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 22, 2010 | Garmin nuvi 200W GPS Receiver
Ive been getting the message ''acquiring satellites'' since yesterday morning
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Dec 02, 2009 | Garmin nuvi 200W GPS Receiver
I have a nuvi 200, less than 2 yrs old. Has probkems acquiring satelite. Has GPS sw 2.50b and audio 2.20. Also, where and how much is usb adaptor that fits to left side of unit (special plug in to unit
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W.
The usb cable you require is a standard USB to mini-USB cable. MP3 or camera cables will work.
I hope that helps.
___________________
Oct 14, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 755T Issue - Firmware Update and acquiring satellite
Hi Bob,
You need to do a complete reset by turning it on and at the same time press the bottom right hand corner of the screen this will reset it to factory condition. having done that when you switch it on again leave some where where it has a clear view of the sky and leave it for about 1/2 an hour. This should sort it out for you. Best of luck.
Jul 23, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 200
try updating via Webupdater even if you've already done so. There seems to be a problem with the update and doing it again seems to fix it. When updating, and it's already updated, there will be an option to reload it. Do it and post the results.
Jun 28, 2008 | Garmin nuvi 200W GPS Receiver
Screen shows "updating GPS firmware"
Hey, got this problem licked!
Go to the Garmin website and download their latest S/W. It fixes the problem!
May 28, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 250 NOT acquiring satellites
After talking to Garmin talk support, I had to send my unit out for repair. Apparently they could not repair mine, they send me another one ( It is not new) but it works. Luckily I was still under warranty otherwise I would have have lost my money
Mar 02, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
295 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
