Question about RCA HD56W66 56" HDTV
No picture tv powers on, i can here audio but no picture at all. Tried using dvd player to check other inputs but can't see menu to change. Can you help?
  • nick-star Jun 28, 2008
    I HAVE THE SAME PROBLEM WHAT DO I NEED TO DO NO PICTURE BUT SOUND
GET A LAMP.. THE LAMP MAY HAVE COME LOOSE OR NEEDS TO BE REPLACED.. I LOOKED AT RCA.COM AND FOUND THIS OUT TODAY.
Posted on Aug 06, 2008
Tf d Ihave a tf dvd7100 I am trying to hook it up to my tv to plac a movie cd
HI,
Before connecting the the DVD to your TV First of all you have to the audio out put of your for the do the following using the setup menu.
Press SETUP button of of the DVD player to show "setup" menu. Select the audio setup the select the digital out then change to OFF from SPIDF/RAW.
Here i have added a picture which shows how to hookup the dvd player to a TV. Its for the same model that you have .
to make the connection you need two codes
1. 3.5mm stereo to two RCA (for audio)
2. 3.5mm mono to single RCA(for video)
connect the first cord to inoptical/audio and second one to video output of the dvd player.
connect the cable which comes from the video out out of dvd to the video input (yellow) of your TV. then connect the cable which comes from the inoptical/audio of the dvd player to the audio input of the TV (red and white ).
You have to select the input of your TV by pressing the AV/ source selection on the remote of the TV. check where you made the connection on the tv AV 1 or AV 2. then select the corresponding input. hope you will get it worked.
Also Added the image of the cable that you need to make the connections.
25383850-eev1v0sv1zwox43luwgxtns5-4-5.jpg 3.5mm stereo to two RCA (for audio)
Electronics Equipment Repair Center
Jan 25, 2015 | Coby TF-DVD7107 Portable DVD Player
Connecting a sony dvp-sr500h dvd player to sanyo tv. using the red, yellow, white cables that came with the sony player get me no picture, no sound. do I need additional cables? the menu on the tv screen...
Here is the quick start guide
https://docs.sony.com/release//DVPSR500H_qs_EN_FR_ES.pdf
You seem to be using the Video & Audio connection. Start at the Player. Connect cables to YELLOW Video, RED Right Audio WHITE Left Audio Then go to TV and find the YELLOW input RED input and WHITE input. On some TV's they are separate, some combine them with the COMPONENT inputs (Component is 5 cables you will use 3 of them if you only have COMPONENT inputs)
Some TV's have an input button on the remote but no on screen selection. Try pressing the input repeatedly to access the other inputs. Lastly you will not get upscaling if you are using the 3 cable hook-up. To get upscaling use an HDMI cable to connect. Be sure to not have both types of cables plugged in at the same time HDMI by itself is best. If you reply with the modelof the sanyo TV I'll try to get you more info.
Jan 05, 2018 | Cyberhome CH-DVD 300 DVD Player
My dvd player is hooked up to the samsung receiver. I am using two remotes, one is the cable box remote where I hit tv and power and then cable and power and then the red power button on the samsung remote...
What you have to do is select the proper item on the receiver since that is what you have the dvd player connected to. Pressing bd/dvd on the receiver is not necessarily the right thing to do. All receivers have an input or source or function button that will enable you to choose the correct area where your device is connected. The way you have this hooked up may not be right but first things first. You will need to have a movie playing in the DVD player so that you see the numbers advancing. Go to each input/source/function on the receiver until you hear the DVD. Ok great! Now getting the picture is a little more tricky so please follow along carefully.
The cables going from the DVD player to the receiver: The cables should be connected to where it says OUT on the DVD player or hdmi out from the DVD player to one of the receivers INputs. Once that proper connection has been confirmed make sure the receiver is connected to the television for both video and audio. You must have a video cable as well as audio cables between the television and the receiver or an hdmi cable. If it is not connected to the television in this way that is the problem right there. In fact you probably have a cable going from the television's audio OUT going INto the receiver. In order to see your DVD player you will also need to connect the receiver's video OUT to the television's video IN.
You will need the television's remote to be able to change the source/input/video/aux on the television. You might be able to change it with the cable box remote by pressing tv and then input/source/video.
ALTERNATELY: You can connect the DVD player's Video OUT directly into the television's INput. The DVD player's Audio OUT cables would be connected directly to the receiver's IN.
Either way you will have to choose the correct input on the receiver as well as on the television itself.
May 16, 2011 | Samsung HW-C700
Connected my DVD player to my new Sony Bravia BX4 40 with scart, get a picture but no sound. also tried to connecting my PS2 and i am getting the same problem....any ideas!?
Using the manual that came with your TV, recheck all of your connections. They are specifically marked for audio and video and have the connections for a number of components. I have a Sony Bravias and my audio cables are yellow on the end and the videos are red and white. What sort of TV Service do you have? Cable or Satellite. When you are wanting to use the DVD player, you have to change the input using the the input button on your remote to get an onscreen menu of all your components.If you have Satellite TV, you can use your Satellite remote to do this.
Let me know if this does not help. These are great TVS!
Dec 29, 2010 | Televison & Video
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Picture but no sound
It is most likely the SAP setting is in place. This will kill the sound
To reset the audio, go to the on-screen menu and select the setting for audio and make sure it is on stereo rather than SAP (second audio channel).
toggle the two and see which is compatible to ur Dvd player
thank you
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
No sound
Steve make sure that the coax is connected to the output on the DVD/VCR and to the TV's cable or antenna input. This should give you picture and sound on CH 3. If you use RCA jacks you must also use the yellow video plug as well on the same input on the TV as well as on the DVD to get both picture and sound to the tv. The place yoou put the RCA's on the TV will determine where the image will be displayed e.g. if connected to VIDEO 1 on TV YOU MUST CHANGE THE TV TO THE INPUT NAMED AUDIO 1. You can do this by using the input or source button on the remote control for the tv or go into the tv's menu and perform the task that way. I hope this helps you resolve the issue. Thanks for using Fix Ya and let me know if I can be of more assistance.
Oct 15, 2008 | RCA DRC8295N DVD Recorder/VCR
DVP642 DVD Player is only working in Audio mode
Mine does the same. Cannot get a picture using the Yellow RCA output. Use an S-video cable if you can - it should still work. If you get a black and white picture using the S-video output, go to MENU > VIDEO page and change the output from PyBywhateveritis to S-video and the color will come back. I only found out mine was broken when I needed to use the s-video cable for something else and tried switching to the Composite Video (RCA) to no avail no matter how many cables or TV inputs I tried.
Mar 15, 2008 | Philips DVP642 DVD Player
Why won't my TV pick read my portable DVD player?
probably you need to change your input setting using the menu in your tv. use your remote control in finding that menu. good luck!
Feb 13, 2007 | Daewoo DVQ9H1FC 9 in. TV/VCR Combo
RCA HD56W66 56" HDTV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
