Question about Kenmore Dryers
Doesnt heat. we replaced the heating element & still no heat.
  • 1,531 Answers
You need to check all the thermal fuses that are near the heating element if there is one that has no continuity then it needs to be replaced.also check and make sure the correct amount of power at the terminal block if there is not 220 volts at the terminal block the unit can work but not get hot..will look for comments a model number will be helpful.
Posted on Nov 13, 2010
Three of the four stove stop heating elements thermostate doesnt work. It is either on fully or have to turn off to manage heat. remedy ?
Hi, You will have to replace the switch with a new one. That is all that is needed . Good luck.
Jan 12, 2016 | Dryers
Hi, my dishwasher doesnt appear to heat the water-am I able to get a replacement part? Thanks
mfr,, model? (hot water is to be supplied into the washer, it seems cold water is supplied?)
there's a 'heating element' but i guess this is use to dry the dishes.
"heating element" should be available, search using mfr. & model no.
Oct 13, 2015 | Dishwashers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Black & Decker FC150R heating element needed
go to http://www.blackanddeckerappliances.com/
God bless you
Jun 22, 2012 | Applica Kitchen Appliances - Others
Cycle works, water doesnt heat
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
HEATER COIL DOESNT WORK
heatman101
Jan 25, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Jan 06, 2008 | Maytag Performa PAV2200
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
