Question about Acer Aspire 4520-5141 Notebook
Good day, May I inquire how to fix Acer Aspire 4520G there is no display on the monitor, but i heard the fun running. What are the possible cause of this, is it video card, CPU or motherboard. I'd tried the memory into other laptop, its still working. Thanks
  • Acer Master
  • 629 Answers
To help isolate it, try to connect an external monitor to it. If display works on the external display, problem would be the laptop LCD. If you can remove and reconnect the LCD cable to the motherboard, that may help. If no display on both display, try to test the hard drive to another laptop if you can, or you can try reinstalling Windows. If no display at all, chances are, it is the video card.
Posted on Nov 13, 2010
  • nmt_3570224 Nov 13, 2010
    thanks for the reply, I've tried to connect it to monitor before but still no display, and I've tried also to remove the hard disk and power on but still no display even POST.
  • Rodie Nov 14, 2010
    chances are, this is a motherboard or video card issue. try to remove and reconnect the memory modules of your system and if no improvement or no change in the status, you can consider it being a video card, or motherboard problem. If the video card is integrated to the motherboard, you'll sure know you need a replacement motherboard.
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
Vidoe card for acer aspire 4520g laptap
drivers you can get from acer support website, if you need to buy video card then we need to know model of card or laptop with part number as minimum
Nov 12, 2012 | Computers & Internet
Driver for touch pad of acer aspire 4520g
Hi
www.acer.com go to support/downloads give your make model and operating system
then scroll down to your driver and download it
good luck
Feb 02, 2011 | Acer Computers & Internet
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
ACER Display Issue
i have heard of something like that, not with an acer tho. but. if you bought your pc new it would have come with a series of disks. try running the version of windows it came with again and see if that makes a difference it sounds like a problem with the software. if that does not fix the prob defitanly contact acer and consult them cause as you already said it might just be a hardware glitch. good luck. it is really hard to say with out lookin at it but, that is wat i think you shouldtry first. run the disk again which will re install everything and hope that it fixes the problem
Nov 20, 2009 | Acer Aspire 9420-6426 Notebook
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
Acer -Video Display Issue
Hi there.
This could be 1 of 2 problems, lets start with the first.
#1 Bad display drivers
Boot the laptop into safe ( i am assuming you know how to do this by your post ) on the computer icon, right click and select manage, a new window will pop up and then select device manager, the list will populate with hardware that installed on the PC, look down the list for display adapters and click on the + sign on the left hand side to open the tree, then right click on the display adapter and select uninstall. Now restart the laptop and let it boot up as normal, if the display drivers were bad it will boot with the screen resolution as large, once you log in it should auto detect the display and install the drivers (you may have give it permission) if this works then that was the problem.
#2 Faulty graphics card.
Take advantage of the manufacturers warranty and send it in for repair as there will be nothing you can do about this kind of hardware failure.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 19, 2009 | Acer Aspire One PC Notebook
External widescreen monitor for laptop
You have to make sure that the laptop could provide the required resolution of the monitor, because of the laptop could only give1280 x 1024 and the monitor is requiring 1600 x 1024, then expect that you will get that result.
Try changing the resolution of the laptop. Set it to 1024 x 768.
Have a good day!
May 18, 2009 | Acer Aspire 3002LCi Notebook
Acer 5315 laptop black screen computer doesn't respond but there are lights on
perhaps hook up an external monitor. does that display information ?
Robert
Aug 28, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 4520-5141 Notebook Logo
383 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
