Question about Hitachi 43FWX20B 43" Rear Projection Television
The picture on my hitachi 42' r out of wack~ I checked the back an the red light wont line up with the blue an green~ Is there any way I can move the red manualy~? I covered the red for now so I can c the picture~
  • 1,476 Answers
Gui harcor,
Sounds like you have a classic case of convergence IC failure. It will only get worse if you do not fix it. It is repariable by anyone with patience, some skills with tools, good soldering skills and of course someone who is very conciencious. If you still want to try to give it a shot I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will walk you through the process as well as link you to the very best place to get the repair parts.
Thanks for using FixYa and for the excellent rating. Great ratings keep experts helping everyone solve their problems. Thank you.
hardrocko
Posted on Nov 13, 2010
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Unable to enter convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 08, 2009 | Toshiba 42H82 42" Rear Projection...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
My husband moved the tv from one table to another, and now the color is all screwed up. Mostly purple and green. What's the problem? It's an Hitachi 42" plasma tv.
Usually this is caused by unproperly hooked up component video cables. Check the green, blue and red component video cables on the tv and on the device (cablebox) to hopefully solve the issue. Sometimes one just pulls loose also
Jan 10, 2009 | Hitachi 42HDS69 42 in. Plasma Television
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
