Samsung 42 inch projection tv. around 3 years old. have white dots on the screen. Payed a lot for this junk tv.
  • 1,476 Answers
Mikechamb606,
A model number would have helped me diagnose your unit but because you say that you have white dots on the screen, and the unit is only 3 years old, I will go with what I believe your problem is. I am assuming that you do not have a CRT projection unit. I believe you have an lcd projection tv which is starting to have TFT panel failures. As they age they lose more and more pixels which show up as white dots. The only cure for this is a new optical engine. Cost could be on the order of $350 US. The replacement is not that difficult and can be done using my tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which will walk you through the process as well as link you to the best place to get the parts you need.
Thanks for using FixYa and for the excellent rating. Great ratings keep experts helping everyone solve their problems. Thank you.
hardrocko
Posted on Nov 13, 2010
  • sunflower195 Dec 01, 2010
    UGggggggggg!!! Same problem with our 3 yr old tv. I like to play connect the dots with it or find the big and little dipper,,,which I did. LOL mine is a Toshiba. Just put out 300 plus bucks a couple months ago to have it fixed for it just blacking out, now this. NEW TV here we come.
  • Kim Yearick
    Kim Yearick Dec 02, 2010
    mikechamb606,
    If you are going to get a new television set here is some advice to help you.
    Only buy the name brands such as Sony (the best and worth every cent), Panasonic, RCA, Toshiba or other major brands. I mean it, do not buy the no name cheap units thinking you will save money. It isn't going to happen. By the way, Vizio is in the junk category.
    Honestly though, they all have problems because 1) they are made in China and 2) lead was taken out of solder some years back making it brittle and melt at a higher tempreture. This partially destroys components before they leave the factory and then they fail in short order after you own the TV.
    As far as the best type unit to purchase. I would not buy a plasma. Flatscreen LCDs may or may not be reliable, it's the luck of the draw. DLP projectors seem to be the most reliable if they are name brand but still they can have issues. That's where the next part comes in.
    I would recommend an extended warranty for when the unit implodes, as you know it will. I never recommended extended warranties before because they were a waste of money ten years ago, but with this junk they are a neccesity to save your bank account.
    I hope this helps ease the pain.
    Thanks for using FixYa and the great rating.
    hardrocko
We have a 6 year old tv. We are starting to see
hello,
If your problem like pict below :
(worst dot's on screen)
Change the DMD.
Good luck.
Mar 23, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
My Samsung 67" has white
I have the same problem on my 42" Samsung. It started as one dot now there are six. The TV repair shop told me they can sometimes fix it by adjsuting the voltages. If not it is the DMD board. I called Samsung on Jan. 6/11. They told me that as of Dec. 31/10 they would no longer repair the sets for free.
Nov 06, 2010 | Samsung HL-S6767W DLP TV
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp white dot
If the white dot is on every picture and every input and stays there for a sec. after you press the power button to turn off the tv then suspect a stuck mirror in the DMD.
Sep 29, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Open Questions:
Televison & Video Logo
272 people viewed this question
Top Televison & Video Experts
Electro Med Services...
