Question about HP Computers & Internet
Simple solution I'm sure but I'm a novice. Have an HP Pavillion desk top, model a67001. I want to copy from my digital tape recorder to computer and then burn a copy to CD. Where do I put the jumper into the computer? I know...dumb...but have never done this before. Thanks Mary
  • roweenaa Nov 13, 2010
    Silverdragon,
    OK...I used the wrong termonology for the cable. Do I plug the cable into the front of the computer in the mic or in the back? There are two rows in the back that accept the cable and there are two places marked mic. I know, I'm usually not such a dummy but I've never done this before.
    There is no software for the digital recorder so I'll have to wing it I suppose.
    Thanks
    Mary
    Thank you for your help. I figured it out finally myself.
  • 4,281 Answers
For that connect your digital recorder to computer if it has usb option . You can connect it to computer with usb cable then you can see removable memory in my computer then copy that data to your computer's drive . Then you can burn that data with nero software. You can download nero from below link. Click here But if there is not any usb option on recorder then you need to give output cable from recorder to your sound audio input port of computer then you can record voice on computer with music juke box software. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 13, 2010
  • HP Master
  • 12,061 Answers
Ok, well there is no "Jumper" as such, to get the Digital Tape data onto the PC, it will have to be transferred, usually via, the USB port & cable. Once you have copied the data to the PC, then one can use one of the many Audio burning programs on the 'net.to compile and burn you data.
You DTR should have come with a USB cable and software to install, and use on the PC... You must install this software and Driver before you can use the device in this way. Install the software and then plug the device in, it should be detected and install or ask where the drivers are, once installed you will be able to use it.
Often, though, these devices don't have a driver as such, and when plugged in, they simply install as and show up as a "Drive" in My Computer, as such, one can copy, paste and cut as usual.
However IF it doesn't have a USB and software? Then you could still use it, via the Audio Input, (Mic In) and simply save it as a sound file, say MP3 and then again burn to CD/DVD, depending on what the type of file extension used by the DTR recorder, it may save as MP3? anyway you may simply be able to copy paste from the device to wherever you wish on the PC.
Shut down hp pavillion desk top
This is an XP machine, which is no longer supported. I recommend backing up your personal data asap, and plan on moving to a newer machine and Operating Sysytem. If the machine won't boot, and you have important files on it, you could purchase a USB Hard Drive Adaptor, pull out the hard drive, and copy any important files to another machine. Good luck.
Jun 24, 2014 | HP Pavilion a1410n (ER890AA) PC Desktop
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
Feb 17, 2014 | Encore Technology Portable Cassette...
How to replace cpu cooling fan on HP pavillion MS227 desk top pc
to REplace the heat sink of the HP pavillion MS227 All in one model ..you have to remove the stand on the back,and remove the plactick that cove the whole screen try to use some tool that very shap edge to get through the lock to break out very carefully if you don't want to break the cover.there are some screw that you may need to remove too..but not alot,than after you can get the cover out you should see the madal plate that cover the main board and heat sink,,need to take that out..yo should be able to replace the heat sink from HP MS227 all in on or any of other HP All in one model too...Before you replace the new one make sure you clean youe CPU by use some alcohol to clean it goog and new heat sink need to clean too..need some Thermal compund to put on top of CPU..get it from some PC sale and service...to reduce heat from your CPU...than you ready to go...hope it can help..
Jan 12, 2012 | Computers & Internet
Need a 400W power supply for a HP774y Pavillion Desk Top computer. It must have the dimensions 4 x 3.5 x 6 ish. the cables must come out on the right side (when viewing the fan opening side. Neither...
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day.
Aug 22, 2011 | HP Bestec ATX-1956D 200w HP Part No...
HP Pavillion desk top modela6683w stopped turning on
the first thing to do is to check the power cable, try using a different one, if its okay listen to hear if the cooling system(fan) is spinning, if not then its very likely to be your powerpac
Jul 21, 2010 | HP Computers & Internet
HP Pavillion laptop won't backup to optical drive...CD/DVD-RW; I do have 1 Click Copy (&Pro) installed as well as DVD43. I have tried to uninstall the DVD43 & 1 Click but it doesn't change...
HP Pavillion laptops and every others laptops do require CD/DVD recordable for backup not CD/DVD rewritable. Try to use a CD/DVD recordable to see what will happen first.
Sep 16, 2009 | HP Computers & Internet
Recording voice to computer
XP:
Start
All Programs
Accessories
Entertainment
Voice Recorder
I presume that you have a microphone connected?
May 22, 2009 | HP Computers & Internet
Hp photosmart 3110 and vista compatability issues
hello
goto the hp web site www.hp.com and start with the download & support tab, then download all the software and drivers for your model printer and vista operating system.
then install all you have downloaded and you should be ok.
norm
Nov 06, 2008 | Office Equipment & Supplies
No sound coming through when recording from hi fi tape to computer
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
Jul 01, 2008 | Genius Soundmaker Value 5.1
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
