Question about GE Refrigerators
GE refrigerator Model PDS22MFSBBB. There is no power to the icemaker plug. Unit has a new main circuit board.
eagle338
  • 4889 Answers
SOURCE: Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Posted on Jun 26, 2008
SolutionGuy
  • 331 Answers
SOURCE: Location of GE refrigerator circuit board
The main board is located behind the unit at the lower right hand corner behind a panel that's about 8" X 12".
Posted on Oct 29, 2008
peyton32034
  • 410 Answers
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Posted on Jan 21, 2009
bobicehouse
  • 1524 Answers
SOURCE: Test to see if circuit board is okay
From Appliance Aid.com
WHY Force the Arctica to Defrost if it Don�t Want to? Don't bother using the self-diagnostics feature to force a defrost cycle. On some models � those with control knobs - which technically are not Arctica models (Arctica models have plastic liners with touch pads � Standard GE electronic models with metal liners have knobs) servicers would have to invest in parts to build a �test� control panel, complete with touch pads and digital displays, to achieve this (self-diagnostics) function. Instead, save both time and money by following this helpful Arctica Tip: If a frosted evaporator or a �frost block� is apparent, initiating a defrost cycle may not reveal anything helpful anyway. First, disconnect power and then simply check the resistance across the defrost heater and bimetal circuit at the main board located at the backside. The two associated wires at the main board are almost always BLUE and ORANGE. The heater/bimetal circuit should normally read around 30 ohms roughly. Next, check the evaporator thermister at the main board between thermister input terminals J1-4 (Blue/White) and J1-5 (Blue) to determine that its resistance is greater than 1.2k ohms but not more than 166.8k ohms depending on its ambient temperature. If thermister resistance falls within this range according to temperature (Approximately: 6k ohms at 70�F � 16.3k ohms at 32�F � 51k ohms at 0�F) and the heater/bimetal circuit is diagnosed as good, then replace the main board.
Posted on Apr 30, 2009
Chadha Saab
  • 142 Answers
SOURCE: Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Posted on May 31, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded ยท How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Ge model gsh25jftabb light comes on inside. It
    You need to replace the main control board on the back of the unit. Here is the part to order.
    Roll unit away from the wall, unplug it, then on the lower freezer side of the rear you will see the access door for the board. Remove the screw and cover to gain access to the board.
    Aug 30, 2013 | GE Refrigerators
    GE Refrigerator--model TFX24ZRXA. Replaced water valve. Removed icemaker to replace the dispenser motor. Plugging in the icemaker causes the circuit breaker to trip now.
    Obviously you have a short in your wiring somewhere. perhaps one of the terminals for the dispenser motor were not securely attached. Is there any water in either plug for the icemaker, since breaker trips when you plug that in? Did you plug icemaker in correctly? You can reply here or send me a question from my website: www.FixMyFridge.net
    Mar 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    My icemaker makes ice but does not dispense it or water. Model is GE gss23kgsa ww
    This could be the cradle switch or the main board. When the cradle in to dispense watch the lights on the display if they go off it's the main board.
    Feb 18, 2010 | GE Refrigerators
    Our GE PSC25PSTA fridge drips water from the icemaker
    I have this model also for just over 3 years and it developed the same problem. The issue turned out to be the unit was in defrost mode too long caused by a failing control circuit board (found in the back under a panel cover). The board controls all refrig functions. This was replaced and the unit works normally now. The board costs around $200 plus the service call ... still cheaper than a new refig.
    Feb 09, 2010 | GE Refrigerators
    Icemaker not working, freezer not getting cold enough....
    Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
    The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
    If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
    Enter the model number on one of two websites below to get parts and diagrams for your appliance:
    Appliance Parts From PartSelect
    Appliance Parts Pros
    Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Oct 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Jun 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
    GE GSH25JSRFSS REfrigerator not working
    I had the same problem as do thousands of people with this same fridge. The mother board is bad and needs to be replaced. It is easy to do yourself and the part costs less than a service call.: Unplug the cord from the wall, remove the panel from the back of the fridge (it is about the size of a small shoe box lid) You will see the mother board (ice, water, light, and compressor control unit). It is an electronic circuit board. There are about 5 or so plugs going into the board. Remove the plugs and the retaining screws and search Ebay for the part#WR55x10552 GE Power Control Board. I found one for $74, popped it in, and everything works better than new!
    Sep 03, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
    Refrigerators Logo
    60 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
