Question about Sport & Outdoor - Others
How to install the speedometer on the yamaha kodiak 400 / 2003
I have a Yamaha ATV I would like to know what year it is the vin number is JY44SHA03VA066538
According to your VIN Its 1997
The complete info from dmv is
Destination Market: U.S.
Make: YAMAHA
Manufacturer Name: YAMAHA MOTOR CORPORATION
Model: YFM400FW Kodiak 4x4
Model Year: 1997
Plant City: Hamamatsu
Vehicle Type: MOTORCYCLE
Plant Country: Japan
Body Class: Motorcycle - All Terrain Cycle (ATV)
Drive Type: 4WD/4-Wheel Drive/4x4
Displacement (CC): 400
Displacement (CI): 24.409497637
Displacement (L): 0.400000
Oct 27, 2017 | Yamaha 2004 Kodiak 400 Auto 4x4
1999 Yamaha Kodiak 400 4+4 best way to set motor timing and valves
check youtube for generic valve adjusting procedures, the kodiak is like most of them.
Mar 23, 2017 | Yamaha 2004 Kodiak 400 Auto 4x4
How to install choke cable on 400 Kodiak atv ?
Your information is on the ATV Forum
Throttle cable: remove the 3 screws on the right side of the carb, take off the cover, there is small rubber gasket (red) Don't lose it. you'll see the cable attached inside. move the mechanism forward like you're opening the throttle to get enough slack to unhook the cable.
Choke: on the other side of the carb, the choke cable screws in with a plastic nut (10 mm i think) unscrew with your hand, if its tight use pliers or wrench..its easy to unscrew it.
throttle choke cable removal Yamaha Grizzly ATV Forum
Sep 12, 2015 | Yamaha Vehicle Parts & Accessories
Yamaha 400 kodiak
is it belt driven if it is check belt for slippage if not check fluid in the drive axles and gears
Aug 17, 2014 | 1993-1994 Yamaha Yfm400 Kodiak Bear 4x4...
Where is the battery located on a yamaha kodiak
Much the same for most models with a few minor differences depending on the year and model of bike. Look under your seat.
Jan 20, 2013 | Yamaha Kodiak 450 A 4x4 03 Airbox Air Box
Where is the battery on a yamaha kodiak
at the end of the battery terminals in a box checked "battery"
Sport & Outdoor - Others Logo
156 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
