Question about Canon VIXIA HV30 DV Camcorder
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it) the LCD just shows a blue screen and the timestamp does not move even though I can hear the tape moving. What could be wrong here?
    Guru:
  • 2,178 Answers
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Posted on Nov 13, 2010
  • dzurn Nov 20, 2010
    That worked! I have a Canon ZR60 with the exact same problem of a blue screen during playback. I took a tape I didn't need and recorded over it. Now the camera plays back my video so I can upload it to my computer. Thanks a bunch!!!
  • ankhle Mar 25, 2011
    I am trying this right now with all fingers and toes crossed! If this works, you ROCK
Canon HV10 camcorder - can't get video mode to playback
hi, if you get blue screen,but your recording has been ok, then you must be change LCD FLAP, you sure get fix your camera,
Aug 30, 2009 | Canon HV10 HDV Digital Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
LP/SP mode
Seems your Canon doesn't support LP mode playback. Please see its user manual and check its specifications for LP mode playback.
Aug 17, 2008 | Canon ES8400V Camcorder
Camera won't playback or record poss damaged heads
I think your problem is in the analog to digital converters. They seem to not be working, It is probably cheaper to buy a new camera rather than fixing yours.
May 20, 2008 | Canon ZR100 Mini DV Digital Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
No video or audio in playback mode
I Had a similar problem with my 8600. Most likely the camera
is also no longer recording. There were two problems I found,
either one could have caused the problem. 1) the 8mm tape was not
actually moving through the record/play head. With modern cameras. there are no indications that the tape is actually moving.
2) the record/play head is dirty. What I did was remove the
side plate that covers the tape cassette to allow me to verify that
the tape was moving properly. After that, I removed the tape, removed the battery, and used isopropyl alcohol and a q tip
to clean the head. I imagine there are cleaning tapes that one
can buy to do this as well. though I doubt they work as well as
a q tip. THere are two screws that hold the cover on.
Dec 15, 2007 | Canon ES8400V Camcorder
Playback won't work
needs to be cleaned and possibly tension adjustments. most cases this will fit it but the video heads could need replacing.
Sep 14, 2007 | Sony Handycam DCR-TRV245 Digital-8 Digital...
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Playback of my 8 mm tapes on camera
Hello, there can be some contact errors at the flat cables and connectors from the mechanism to the main board. Please contact your nearest Authorized Sony Service. Best regards, Arpi
Dec 13, 2006 | Sony Handycam DCR-TRV530 Digital Camcorder
Canon VIXIA HV30 DV Camcorder Logo
498 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
