Question about Poulan Pro Chain Saw 46cc 20"
I put oil in gas and gas in the oil can it be fixed
    Problem Solver:
  • 6 Answers
YES IT CAN. TAKE OFF BOTH CAPS AND TURN THE SAW OVER AND EMPTY THE TANKS. GO TO AN AUTO PARTS STORE AND BUY A GOOD DEGREASER THAT YOU CAN SPRAY IN THE TANKS AND WASH CLEAN. WAIT TILL DRY AND REFILL HTE RIGFHT WAY.
Posted on Nov 14, 2010
How do you put the oil in? seems to suggest to put it in the gas tank. How much?
Hi Barry, There's two types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) and the 2 stroke grade is just two stroke oil (2 stroke mower ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
http://bpretail.bp.nl/australie/2_stroke_brochure.pdf
Mar 27, 2016 | Garden
Why am i getting gas in crankcase?
You have a stuck float in the carb...the newer carbs a have a small valve that stops the gas from leaking to the ground when stuck..however it now goes into the intake and into the cylinder and open valves and eventual filling the engine with gas oil nix..I had this and found out don't mess with the carb..cause it will happen again..there is a quick and permanent fix..if your tractor has a gas shut it off if not apply one...first if you have gas in oil it must be takin care of now..it can and will fill the entire engine block..so here is the fix..drain the engine block change the filter then remove and ckean the plug..now tape or cover the plug..and slowly crank the engine to blow excess gas from the cylinder. Just keep the plug away..put oil,filter and plugs back..put on a gas shut off or if you already have one..keep it closed at all times when not in operation..here is the important part..when done mowing put the throttle in low and reach up and shut off the gas..let it run unti it uses up the gas left in the carb..when starting open the shut off and let open a few seconds to fill the carb..then start....you must do this eah time you shut it down and restart....or get the carb rebuilt not to say it won't happen again..your choice..good luck.
Jul 01, 2014 | Honda Garden
Problem with Lawn Trimmers & Edgers I put a
Yes, this should not hurt it, just clean the plug and crank until it fires up, it will smoke until the oil has gone. Are you sure it is a four stroke machine?? as most are two strokes and do require a fuel/oil mix.
May 14, 2013 | Garden
Any one knows how to fix an oil pressure, because my oil light comes on. My rpms fluctuate or idles and want to shut down ,but doesnt. Does anyone kknow the problem?
Do u put oil in it often? Have u tried the oil pump? If u r losing pressure but not oil then u just may need to get a new oil pump. Their really easy to change.
Apr 09, 2012 | 1998 Cadillac Eldorado
Son put gas with oil, if i drain it will that fix it or is the fix more detailes it will start but blows out gray smoke
You can drain it and it will be just fine. Putting mix gas into an egine that just needs gas is fine. Its going to smoke untill all the oil is burnt up. He didnt hurt a thing. Altho if you put just gas into an engine that need mix you will cause alot of problems so becarefull with that. Good luck and if you have any more questions about it feel free to email me.
A.J. Weaver
Mar 30, 2012 | Briggs & Stratton Garden
I put gas in the oil and oil in the gas can it be fixed
As far as gas in the oil I presume you are talking about bar oil. I wouldn't worry to much about that. Empty out all you can and refill with bar oil. With oil in the gas I would drain all I could out of fuel tank,then remove sparkplug and pull srarter rope several times. With plug still out i would pour 1-2 ounces of of gas into plug opening and let it set for a few mins.,then dump out remainging fuel. Once again I would pull starter rope several times. Reinstall plug and refill gas tank with proper fuel oil mix. Try to start. If you're lucky you can get it to fire and burn off excess oil in afew pulls. If you can get it started I would run for just a couple of mins,then shut off and drain gas again. Hope this helps. Thanks.
Nov 13, 2010 | Poulan Pro Chain Saw 46cc 20"
Mixture 0f gas and oil
Go to your supply store and purchase one small bottle or plastic container of 50 to 1 oil. 40 to 1 is ok too - then purchase one gallon plastic can - put the bottle into the one gallon gas can and add the gas - shake and use.
This is the easy way.
Gary @ Fix Ya
Sep 09, 2010 | Craftsman Garden
Poulan Pro Chain Saw 46cc 20" Logo
51 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
