Question about Garden
I put oil where the gas goes and gas where the oil goes
  • 3 Answers
Dump it out and do it right.. no harm done.
Posted on Nov 13, 2010
WHAT IF I PUT GAS WHERE THE OIL GOES
if you mean where the chain oil lube goes then you could have a fire if any sparks occure ! If its where a seperate 2stroke oil feed should be then you will not lubricate the engine internals and sieze the engine ! Just drain out and fill with oil , 2stroke will need to be bled on the side of oil pump !
Jul 05, 2014 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
2010 F 150 oil light warning and wont accelorate
get you a gallon of marval mystry oil drain your oil and filter put a little mystry oil in your old filter rinse it out put back on and oil plug too fill with mystry oil crank truck let it run for 3 min let cool of drain put in new filter and oil if problem still accelorate and oil light still stays on you might have problems with oil pump if oil light goes out and still problems accelorating try changing fuel filter if this doesn't do the job also crack you truck up (if it is carberated carb) take air fiter off carb intake pour a little mystry oil in carb very slowly while running this helps to clean deposites due this for about little at a time you will hear motor sound like choking stop let motor catch up do this for about 3-5 min then pour mysry oil in till motor dies let set for 3 min start motor them put gas treatment (STP) in gas tank this should do the job if you have furl injestion put one cup of mystry oil in gas tank and one bottle of (STP) and atleat 6-10 gal of gas. if this doesn't do the job you may need to tale the truck to a spec.
May 27, 2014 | 2001 Ford Focus
Oil light comes on when i put the clutch in and come to a stop
check the oil level in the sump. Ensure that the idle RPM is at 750rpm or above up to 1000rpm. Check for the correct grade of oil in the engine for you atmospheric temperature.
Feb 21, 2014 | 1994 Mitsubishi 3000GT
Where is the oil drain plug located?
how much is a little and how does anyone confuse a gas filler neck with an oil fill cap, they are in two completely different locations. if you haven't put in more than a cup of gas then it will burn off and not cause a problem therefore you won`t have to do anything but drive it. if its more then the drain plug is on the bottom of the OIL pan and you will or should change the oil and the filter as the gas will be in the filter as well.
Nov 29, 2013 | Daewoo Cars & Trucks
How to put oil in the a/c compressor on a 2001 land rover discovery series ii
you can not put oil on yourself. You have to visit a qulified garage where they know how to do it. The oil goes with the same machine which is putting freon gas in the ac compressor.
Sep 08, 2012 | 2001 Land Rover Discovery Series II
I HAVE 1 2007 DODGE PICK UP 4.7 ENGINE. 75K MILES. OIL GAUGE GOES UP SHPWING PROPER REDING THE DROPS TO ZERO. STEP ON GAS AND GAUGE GOES UP TO NORMAL , LET OFF GAS AND GAUGE GOES TO ZERO. NO NOISE AT ALL...
Most likely an oil sending unit (sensor) should be right by the oil filter take the plug off and see if there's oil coming out of the sending unit if there is that's usually a pretty good sign it's bad if not u need to put a gauge on it to see if it holds pressure (probably cheaper to just buy sending unit if u don't have a gauge to put on... I hope this helps!!!! Good luck!!!!
Nov 19, 2011 | 2007 Dodge Ram Truck
Which port do i put the gas mix in and what do i do if i put bar oil in the gas side and gas in the oil side. Its an M S 170
on your stihl ms170 your bar and chain oil goes on the left side nearest to the bar and gas-oil mixture in the right side nearest to the throttle handle. if you put the wrong things in the wrong tank just flush them out with the right stuff.
Sep 23, 2011 | Garden
Oil light stays on when I start engine but goes off after a while
When you give it gas or idle for awhile the pressure will build up to normal and turn off the light.
If you are consuming oil and coolant you should check your head gasket also.
May 19, 2009 | 1994 Nissan Sentra 4-Door
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
