Question about Kohler K-3384-2 San Raphael Elongated Toilet With French Curve Quiet-Close
I drop my underwear into the toilet then i flashed it that cause it cloged how to solve it ??????????
    Genius:
  • 1,015 Answers
If you have a plunger you can try to force it on into main line where it should go on out. You can get a inexpensive toilet auger at hardware store,about $15.00 and try to hook onto them and pull them back out or push them on through. If you've never used a closet auger you just insert end into toilet bowl with coil retrieval end into opening in bowl. hold hand crank with one hand and auger body with the other and rotate crank in clockwise direction. Use hand on auger body to hold it in place and continue crankink. I would reccomend you go in about two to two and one half feet. Then cotinue crankink while you pull back on cable to remove it from toilet. I would not crank in opposit direction unless cable gets caught. Hope this helps you. Thanks
Posted on Nov 13, 2010
Why do we need to wear underwear ? Are they useful?
hi lata.
Officially called tinea cruris, rot is a skin infection caused by wearing tight or wet clothes. As long as you keep yours clean, wearing underwear reduces your risk of getting rot. Underwear absorb sweat well, unlike pants, jeans, and shorts in general, keeping your boys dry.15 Jul 2015
11 Reasons Why Men Should Wear Underwear Instead of Going ...
www.dudeundies.com/.../11-reasons-why-men-should-wear-underwear-instead-of-going...
or go to this link.
Why do we need to wear underwear Google Search
Nov 18, 2017 | Washing Machines
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
I have a saniflo pro used for toilet , whb and shower .Unit works ok until soap ,shampoo is used which causes foam to come out of the vent .Any ideas would be appreciated
go to spa dealer and get anti foam chemical pretty cheap drop a few drops in tub before draining or a couple drops in sink before draining tub will solve problem
Feb 28, 2014 | Home
I can see water trickeling on the bottom of the overflow tube. Already replaced gasket and removed the fill tube. Very slow, about every 20 min. the fill valve kicks on for about 5 sec.
The problem is your flapper. It is leaking water into the bowl, causing the valve to kick in as the water level slowly drops in the tank. It will also solve most condensation issues as well.
Aug 23, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Jul 29, 2011 | Lavelle Industries Korky& Universal Toilet...
Toilet won't flush all the way. Drains real slow, sometimes flushes just fine. No drains are cloged. Water fills up just fine. You can hear it draining its just real slow. When we use the plunger it...
I wrote a tip that might apply to your situation:
http://www.fixya.com/support/r6633961-toilet_doesnt_flush_water_just_spins
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Eljer Toilet Onepiece Canterbury ...
Caroma Sydney 305 toilet growls
this is caused by a slight leak in the wax ring causing a gurgle sound, remove it again and reset the wax ring should solve your problem. .
Jan 26, 2010 | Caroma toilet - water saving Sydney Low...
Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Aug 01, 2009 | American Standard Traditional Champion4...
Sony ericsson w580i water damaged
To solve your problem, Go to the calls menu and turn virbration 'Off'. If this doesnt fix the problem, permenant water damage maybe the cause.
Best of luck,
Matt
Jan 28, 2009 | Sony Ericsson w580i Cellular Phone
Kohler K-3384-2 San Raphael Elongated Toilet With French Curve Quiet-Close Logo
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
