When it gets hot, the receiver shuts down. sometimes it will work for days at a clip. turn it off for an hour and it goes right back on...
    Sergeant:
    Champion:
  • 293 Answers
Loose board connection.Try to resolder the power supply connection.
Posted on Nov 13, 2010
While watching satellite tv, receiver will work fine for a good while (an hour or more), then you begin hearing what sounds like static in the right front channel, followed shortly after by the receiver...
Sometimes equipment gets too hot and starts glitching. Try an improve cooling and air circulation. Often standing the thing on one end so it's tall will help keep it cool. See if it goes for longer with better cooling.
Oct 29, 2013 | Denon AVR-1911 Receiver
UNIT WILL SHUT ITSELF OFF WHEN IN USE SOMETIMES AFTER 10 MINS SOMETIMES TURN BACK ON AND IT WORKS AGAIN SOMETIMES WON'T COME BACK UP FOR A COUPLE OF HOURS
I suspect that the power supply is not making a proper connection and comes loose in the socket, the gps unit then is forced to use battery power but since the battery is not fully charged yet when the battery power is to low the unit shuts down and will stay down till enough of a charge or the power supply gets bumped and makes a solid connection again.
Jun 11, 2010 | Garmin nuvi 260W GPS Receiver
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Yamaha HTR-5890 Receiver
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Aug 28, 2008 | Sony STR-DE445 Receiver
Mitsubishi Projection TV WD-62525
this set has 3 temperture sensors.If the set gets too hot it will shut down.
first clean the cooling fan as it may be full of dust.
if this is not the cure the one of the sensors is likely bad.
Thanks Guy9
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Random shutdown
The power supply would have been my 2nd option too. It can build up quite a bit of dust which gets very hot inside and overheats. Good thing power supplies are cheap. I assume since you cleaned the heatsink area that your fan is working and plugged in. A bigger fan might be needed too.
Oct 28, 2007 | Dell Dimension 8400 PC Desktop
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
