CD player shows no disc when CD inserted - Audio Players & Recorders
  • 2,071 Answers
The problem of your cd player have a displayed "no disc"is the common problem of defected lense, you better change the lense ,so performance will come back again.
Posted on Jun 18, 2008
No disc cd
laser is probably bad
Jul 09, 2013 | Audio Players & Recorders
BOSE 3 CD PLAYER DISC 3 SHOWS DISC ERROR AND WILL NOT EJECT. TRIED SLIDING OLD DISC UNDER STUCK DISC AS RECOMMENDED WITH NO SUCCESS
hi,
Its because of the disc three is out of its potion in the tray. You have to remove the mechanism to remove the disc from the tray. You have to be very carefull while removing the mechanism because the cd loading mechanism is a very complicated part of cd players . Because when you remove the mechanism to eject the disc, the timing of of the the machanisum can be changed this will lead to malfunction of the loading arms and wheels and will cause serious damages to the mechanism. If you are not aware of how to remove the the try to contact the bose servicing centre.
If you are confident the try to remove the cd manually.
OK
Nov 25, 2011 | Audio Players & Recorders
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
CD Payer PD-M426. When cartridge is inserted, Player starts at disc 1 then immediately to disc 2 right to disc 6, then zero, without playing any of them. All the other functions seem OK so it seems the...
Hi Peter,
First thing to ask you to check is that the discs have been inserted into the cartridge the correct way... that is writing facing down. Check that first and let me know how you get on. Happy to work through it with you.
regards
robotek
Dec 10, 2008 | Pioneer Audio Players & Recorders
CD player TEAC DC-D350 When inserting CD >>message 'disc' shows up. Suspect Laser diode faulty. Should the Laser be on only with CD inserted ? or anytime when player is 'ON'...?
It must probably be a laser faulty, however it could also be derived from something that you can solve by cleaning.. The laser should be on only with cd inserted.
Sep 03, 2008 | Teac Audio Players & Recorders
71 people viewed this question
 Grubhead
Grubhead
