Question about Mitsubishi Televison & Video
I have a tv I purchased in 1995 Model CS-27303 serial # 539484 the volume cannot be raised and there is very low volume. I do not have the original remote and cannot use the closed caption either. what can I do do you possibly have a remote for this model? Or how can I make the volume louder? Sophie Spagnuolo
  • grams191 Nov 13, 2010
    Yes, it was helpful. Thank you so much. Sophie Spagnuolo
  • Mitsubishi Master
  • 12,061 Answers
You do have a slight problem indeed.... well if you don't have a remote for your exact model it's nearly impossible to perform all the functions on the TV. Especially closed caption, that can ONLY be set/unset via the remote.
Now you can obtain "Universal remotes" BUT you must be very careful that they do actually, specifically state, that your make and model is supported, then it's OK anything else and you are wasting your time. See web link below.
http://en.wikipedia.org/wiki/Universal_remote
The low volume may indeed be able to be restored via the remote, usually though the Volume, should be able to be controlled fully via the buttons on the actual set. ALL sets have a series of buttons that should allow one control over, the Channels, the Volume, the Menu, On/Off, and Enter/OK. Using these should enable you to at least have rudimentary control over your set.
However with the age of your set, it maybe the Audio Output Amplifier that is failing? If when you obtain a universal remote it cannot change the volume, then you will need to get the set looked at by a professional, but please remember that costings can be high, and with a set of this age it may be better, putting any monies that would have been spent on repair, towards a new set with a warranty? As if it is this component, then you may expect other failures too.. again, due to the age.
FYI below is a link for your service manual.
http://elektrotanya.com/mitsubishi_cs-27201,27303_sch.pdf/download.html
Posted on Nov 13, 2010
I have a mitsubishi tv model cs-27303 without a remote control. I purchased a universal remote and I need to adjust the color but the menu screen will not come up. The pictice is dark and the tint needs to...
Try using another code marked under the brand of the television in the manual of the universal remote, one of the codes should work and let you open the menu.
Aug 03, 2008 | Televison & Video
We have a Magnavox TV model 20MS3442/17 bought in 2004. Without touching the remote control, the volume will lower very low and eventually raise back. If, when the volume is low, we raise the volume to...
1. Find the 5 & 12 or 9 v line caps. Try to replace electrolitic caps.
2.Find out the keypad pin from the processor and suck it. Then use only remote.
Oct 24, 2017 | Philips Magnavox 20MS3442 20" TV
Low volume output and very low volume when digital broadcast
if you are using a digital converter along with a standard tv , you have one volume level low making the unbalance sound a humming sound, if it is directlly into your tv, check your settings on your tv bass, trebile, by the sound of it you probably have a digital converter , if this is so, raise the volume of your TV to mid point that raise /lower your volume on the converter and it should be fine, also make sure your ouput channel is not the same as your broadcast channel in your area, example,,if your area uses channel 3 for broadcast, set your rf output to chann 4 , and vice versa.
Aug 21, 2009 | Televison & Video
Need to lock television volume on high when television is shut of
Please check in TV menu for Intelligent Volume option and turn it OFF/ ON
Let me know exact model number of TV to help you more precisely.
Feb 11, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Panasonic tv volume trouble.
i have panasonic colour tv model tx28DK1 Serial No.1550327 . I lost remote control and my tv button is also broken. and i bought new Remote Control MUNRO RC81S. bUT I CAN'T set up my TV. hope you will help me
cheers
Nov 06, 2008 | Televison & Video
Mitsubishi cs 27303
try
0150, 0019, 0093, 0178
or
150,019,093,178
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
